R
Rejean
The set have resistor r217 burn (ABL line), when power is apply the HV
does not come on and arcing was appening across this resitor, the power
supply was making abnormal noise. so i have decide to replace the
flyback and the resistor (10k 1/8w), then when a turn on the set whit
the new flyback, some noise appen then the fuse blown f470. i replace
the fuse after checking Q404(horizontal output) when power on, the
relay click that it, so i have found at ic Q510 ta1316an the horizontal
output of the ic is very to low (pin26 40mvp-p)vcc voltage is 9 volts.
I think with the new flyback and resistor the ic as gone bad i will
like to replace it but i am affraid to blow the ic again, does anyone
have something about this HD set.
Rejean Nadeau
Technitonique
Rejean Nadeau
Technitonique
