TORQUE DETERMINATION
Discussion in 'General Electronics Discussion' started by zms, Apr 29, 2016.
  1. zms
    zms
    17
    Apr 29, 2016
    HI all,
    I am new here.
    First of all, sorry guys for posting something which is irrelevant to this section, but yet i think this was the closest.
    what i want to know is how do we experimentally determine, the maximum torque offered by a ceiling fan motor, (the type in which the motor body rotates along with the blades).
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    The torque generated will be that demanded by the fan, the motor should be designed to provide this with ease. The torque will be proportional to the square of the speed.
    The way to measure the toque is to mount the motor on a bearing so that the motor body can rotate, limit the rotation with a radius rod and tie a bit of string to it, measure the tension in the string.
  3. Ratch
    Ratch
    1,075
    327
    Mar 10, 2013
    At what speed? Starting or max rpm? You should Google for a Prony brake. That's the proper way to measure torque and everything else that rotates.
    Ratch
  4. Minder
    Minder
    2,984
    631
    Apr 24, 2015
    Small ceiling fan motors are usually shaded pole motors and do not have that much torque.
    A crude way would be to remove the fan and measure the current, replace the fan and re-measure
    The torque is directly proportional to current.
    But other factors make this an imprecise method, especially for this type of motor.
    M.
  5. Bluejets
    Bluejets
    4,151
    879
    Oct 5, 2014
    Ceiling fan motors are capacitor start/run not shaded pole.
    Very low torque.
  6. Minder
    Minder
    2,984
    631
    Apr 24, 2015
  7. zms
    zms
    17
    Apr 29, 2016
    yeah i am talking about the capacitor-start-capacitor-run types.
    the ones which are known as industrial fans (without light kits)
