TORO leafblower repair?
P
PaPaPeng
Bought at a garage sale a TORO Rake and Vac model 51549 leaf blower.
Worked twice then quit for good. Opened it up. The motor and switch
are good. Between the switch "live" wire (+) and the motor is a
black block of plastic with the live wire going in and a blue wire
exiting to continue to to motor brush terminal. This part is open.
What is the function of this part and can I get a replacement,
preferably generic from an electronics store? If not is there any
downside to my just bypassing this part and connect the switch
directly to the motor?
S
spudnuty
I'm not sure from your description but I have one of these (found mine
in the alley) i think mine is model #51567 but a little hard to read.
Mine wouldn't run until I realised that it had an interlock device that
wouldn't allow it to run unless the vac tube was locked into the
bayonet mount at the impeller input or (and I'm missing this part ) a
protective screen that locks into the same place when it's used as a
blower.
Richard
James Sweet
Is the motor universal wound or permanent magnet? If it's the latter, that
block is probably a diode.
P
PaPaPeng
Its a universal wound. There isn't any interlock on any of the
mountings. My guess is its some kind of thermal protection for
overloads. Perhaps one way round is to replace it with a fuseholder
and put in 3 amp fuse.
S
Sam Goldwasser
If it is a diode, then make sure you tested it in both directions!
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
T
Tony Marsillo
As Richard said, that is the safty interlock. Unless the inlet cover is
installed the blower will not run.
P
PaPaPeng
Made a final check. It is an impeller cover interlock switch. The
sponge packing around it was hardened and hid the switch mechanism
from my sight. Thanks.
