Tool-activated vacuum
Discussion in 'General Electronics Discussion' started by jamesho, Apr 1, 2017.
  1. jamesho
    jamesho
    Apr 1, 2017
    Hi
    I'm trying to make a tool-activated (chop saw) vacuum cleaner, and I'm haveing a few issues that i hope one of you fine people may be able to correct me.
    I'm using this circuit
    https://cdn.instructables.com/FHS/MUSM/GZHJZI61/FHSMUSMGZHJZI61.LARGE.gif
    And a solid state relay, a Fatek SSR-25AA.
    I have built and it part works.
    Switching on the saw, the vacuum starts. However, the saw does not work.
    The relay LED illumates when the saw is switched, but it's just doesn't spin up. I've confirmed the saw is good, by powering separately.
    Any help would be appreciated.
    James
  2. davenn
    davenn Moderator
    13,813
    1,945
    yes, that's right, because you cannot power the saw in series with the relay
    MOST stuff on instructables www site is crap, garbage, waste of computer and internet space
    I assume you mean Fotek ... I can find no reference to Fatek
    presumably this is the relay you have ? note the input and output voltage ratings
  3. jamesho
    jamesho
    Apr 1, 2017
    Fotek is the one...
    Thanks for confirming I cannot power the saw in series with the relay.
    The voltage on the relay look the same.
    80-250VAC input, 24-380VAC
    Is than an issue, both input and switched are 240V?
    If I cannot power the saw in series, any pointers how i can make a tool-activated vacuum?
  4. davenn
    davenn Moderator
    13,813
    1,945
    the problem is you cannot draw the current required by the saw through the relay circuitry
    you need additional circuitry
    the power switch for the saw needs additional contacts so that it also switches power to the relay input
  5. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    A current relay could be used where a high current instead of a high voltage is used to pull the relay in.
    Alternatively, a current transformer with the saw current passing through the primary and the secondary connected to a load resistor and the SSR.
    I think that devices similar to what you want are available but do not know where to find them.
  6. (*steve*)
    25,491
    2,833
    Google "green power board" They typically have one or two outlets which turn on the others when power is drawn. You'll need to check that these can switch your load safely, but they're a ready-made option that doesn't require fooling with mains voltages.
    Incidentally, that instructable seems to use a current relay, although I have little doubt that this is either not mentioned or is buried somewhere. A link to the actual instructable would help, but only to confirm stuff we already know (either about the circuit or instructables themselves).
  7. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    Did I miss something? Why not a 240VAC relay in parallel with the saw? Use the contacts to switch the vacuum on and off with the saw switch.
    Ken
  8. (*steve*)
    25,491
    2,833
    I guess because it needs to be after the power switch for the saw. Otherwise the vacuum will be powered whenever the saw is powered. And you might as well just power them from the same outlet -- no relay required at all.
  9. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    Many years ago I had that problem.But starting the saw and the vacuum at the same time would trip the breaker in the panel. I made a circuit that sensed the saw current and delayed the start of the vacuum by an adjustable delay of a couple of seconds. I also added an adjustable delay after the saw stopped before the vacuum shut down. Caught the dust while the blade was spinning down. And a switch to select the automatic start/stop or run the vacuum by itself. Posted on an electronics group. Months later this what appeared on the market: https://www.woodcraft.com/products/...acuum-switch?gclid=CPKa8vTehdMCFZC4wAodNr8ELQ Can't believe it was a total coincidence. But, they marketed it and I didn't. Also made a knee switch, with an added lightweight remote start/stop pendent on a coil cord. And clip the attach it to my belt or shirt. This would allow me the hold up the near end of an 8-foot board to be ripped, without having to hold it and reach for the knee switch 6 feet away.
    Ken
