Toggle Switch Covers
Discussion in 'Datasheets, Manuals and Component Identification' started by mooginnyc, May 4, 2015.
  1. mooginnyc
    mooginnyc
    40
    Feb 3, 2010
    Hello,
    I'm having trouble sourcing a specific part. I am in need of 24 red rubber toggle switch cap/covers. Specifically, the exact ones that are included with these radio shack switches:
    http://www.radioshack.com/spst-high-current-mini-toggle-switch/2750324.html
    I'm pretty sure radioshack doesn't sell just the caps. I tried finding some thread covers, but the ones in stores are too big, and I've had bad luck guessing the correct size when ordering online.
    Does anyone know of a place that sells just covers like these?
    mooginnyc
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,081
    Dec 18, 2013
    Ring RadioShack, they might be able to help.
    Adam
  3. mooginnyc
    mooginnyc
    40
    Feb 3, 2010
    Thanks.. I won't hold my breath though. Actually, they are quite marked down now I guess due to the bankruptcy. I can always use toggles. I might just order 24 of them and steal the red caps for this project.
    But are there places that just sell the caps? Maybe I'm not typing in the correct term.
    I appreciate the reply!
  4. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    This is a joke, right? Even before the bankruptcy, an inquiry of this sort would be met with a blank stare or the telephonic equivalent.
    The parts you're looking for are called "vinyl switch caps". Most manufacturers of miniature toggle switches offer them, C & K for example. You'll probably need to make a few measurements of your toggles to insure a good fit. Mouser or Digikey would be good possibilities for stock.
    hevans1944 likes this.
  5. hevans1944
    hevans1944 Hop - AC8NS
    4,536
    2,112
    Jun 21, 2012
    If you have the patience for it, you can buy at many hardware stores a can of red plastic "stuff" used to coat tool handles to provide a better grip. Just dip the toggle switch handles in it and suspend over a drip catcher (like newspapers) for 24 hours. Repeat if necessary until you get the coating thickness you want. But I seem to recall that for miniature toggle switches you can purchase the "vinyl switch caps" that @KJ6EAD mentioned. Check with a major on-line electronics distributor like Allied Electronics, Newark, Digi-Key, etc. and look under the product pages of a specific manufacturer, like C & K. Trying to find stuff like this is like trying to find nut and washer hardware for panel-mounted switches and potentiometers. Not commonly stocked, but usually available if you are persistent.
  6. mooginnyc
    mooginnyc
    40
    Feb 3, 2010
    That's a good idea! Thanks. They're actually for little mechanical latching switches. The plastics caps they come with are too big, and I had luck trying the vinyl caps from some radio shack toggles (they come with 3 colors). I'll check C & K. I tried mouser and jameco with no luck. But maybe I wasn't searching correctly.
Similar Threads
Loading...
