hello there : )
I plan to use lots of flip flop ics ( cd4013bc ). At times I will need to reset them all at the same time so that all the leds go off on my circuit board. I hope to do this via a single pin from a microcontroller.
To reset an individual 4013 on my breadboard: I have to disconnect a ground wire to pin 10 and then apply 5v to the same pin (10) and release, then I need to put the ground wire back also. ( basically toggling between GND and 5v)
to do this via a microcontroller. I am planning to use another flip flop with the Q outs connected to two transistors. one transistor will provide the ground and the other 5v, so that i can controll all the resets for all the flip flops with one logic 1 and 0.
I wonder if a 2n3904 be able to provide enough current to 64 flip flop reset pins?
is this a good idea ? Or maybe there would be a better way to toggle between ground and live.?
thanks for your help. : )
(edit)
lol, I just thought , using a flip flop to reset flip flops. i would need feedback to the computer so i know what state the reset flip flop is in. it might work ,but any other ideas would be great : )
(edit)
