To Short or not to Short- that is the question
Discussion in 'General Electronics Discussion' started by SparkyCal, Jun 22, 2020.
  1. SparkyCal
    SparkyCal
    216
    6
    Mar 11, 2020
    Can someone help me interpret this schematic below
    My question relates to Pins 2, 3 and 4 on the 555 Timer.
    Does this schematic require that Pin2 be shorted to Pin 3 and pin 3 be shorted to Pin 4?
    I am thinking not but I am not sure.
    Thank-you
  2. dave9
    dave9
    899
    229
    Mar 5, 2017
    No, if connected together there is a round dot joining them.
  3. Nanren888
    Nanren888
    246
    49
    Nov 8, 2015
    In this style of diagram, only dotted crossovers are connections.
    BTW: the unlabeled input on the flipflop [from 55 pin 3, to "tact" momentary pressbutton] is probably labeled "CLK" or clock on the data, pin-out.
  4. SparkyCal
    SparkyCal
    216
    6
    Mar 11, 2020
    Thanks guys. Just learning about flip flops. I breadboarded this tonight but it failed. Likley because it is not well labeled in certain spots. I'll try what you suggested Naren888
  5. Harald Kapp
    10,025
    2,138
    Which type of JK-FF did you use? Which pins did you connect? Show us an annotated complete schematic diagram.
  6. SparkyCal
    SparkyCal
    216
    6
    Mar 11, 2020
    I need to re-do this. I did it while tired and rushed and that probably accounts for thre failure. if it fails again, when i re-do it, i will post it
    Thank-you
  7. bertus
    bertus Moderator
    683
    237
    Nov 8, 2019
    Hello,
    You will encounter different types of schematics.
    These pictures show the difference between the old method and the new method for drawing a schematic crossing:
    This can be confusing, so take a good look wich method is used.
    Bertus
    TCSC47 and Harald Kapp like this.
