TL431 and PNP for SMPS feedback.
Discussion in 'General Electronics Discussion' started by eem2am, May 7, 2011.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
    Hello,
    I am doing an isolated, offline flyback SMPS.
    I must have low standby power, and also, very little current (less than 30uA) in the opto-diode during heavy load.
    so i must use this circuit
    http://i54.tinypic.com/295r18x.jpg
    .....but do you know of problems with this?....will the feedback loop gain be too high due to the PNP amplfier?
    The PWM controller IC on the primary side has a feedback pin which is connected to the opto collector...........just 90uA COMPLETELY stops switching.
    i cannot use this circuit, as the parallel resistor invokes current in the opto-diode http://i53.tinypic.com/300qt8l.jpg
    ...due to the volt drop across the opto diode
