tips/links for hard drive heads transplantation?
O
Odie Ferrous
hi
any input on taking apart the drive and moving disk arem with heads(
for quantum/maxtor) highly apprecciated..
Good luck.
OD
John Keiser
The HD may contain very powerful magnets which can be fun to experiment
with. As the others have commented, little else will likely come from your
work.
A
Arno Wagner
In said:
hi
Don't. Unless you just want to have a look and breaking anything
does not matter. In the second case I advise to use a screwdriver....
Arno
James Sweet
hi
In a nutshell, forget it.
Jules
He's gunna need a hell of a lot more than a clean room.
Actually, it's an interesting experiment (and one I'd expect to fail),
but:
1) Drives will usually run for anything between a few hours to a few
days after being opened up providing you're careful about the environment
in which it's done. That's long enough to recover data off the drive (but
forget using the drive long term obviously is heads *will* crash
eventually)
2) I'm not sure how much of an issue radial alignment is - won't modern
drives handle the calibration automatically during startup? (and
periodically during use to minimise the effects of temperature changes).
I'd assume that track zero is found electronically, rather than being
dictated by any mechnical resting place of the head assembly.
Head height is doubtless very critical though (even with flying heads) and
for that you would need a lab to set up properly.
There's also the problem of how to physically remove the head stack from
the donor drive - those magnets are *strong* and likely something would
get damaged in the process of removing the head assembly...
cheers
Jules
F
Folkert Rienstra
Rotflol. You a rocket scientist, right?
but:
1) Drives will usually run for anything between a few hours to a few days
Ah, you do this all the time.
'obviously'
its heads
You sure it's the heads and not the platters?
as in God's *will* or did you make deal with the devil?
crash eventually)
Or die of old age.
Ah yeah, those little servo motors adjusting them mechanically at startup.
(and periodically during use to minimise the effects of temperature changes).
Lets hope so as they are as far apart as they can be on the platter.
No kidding.
and for that you would need a lab to set up properly.
Yeah, better start saving for that automatic laser guided
adjusting rig.
And for that laser guided robot that applies it back
into the drive without upsetting 'the adjustment'.
from the donor drive -
Yeah, it is 'obviously' much easier to remove them from the bad drive
and restoring them to the bad drive is 'obviously' a doddle too.
Especially those that apply the downforce to the heads and in need of micro 'adjustment'.
and likely something would get damaged in the process of removing the head assembly...
Your pride obviously if it sticks to your screwdriver while the heads are
still on the platters, making a Karel Appel impression on the platters.
R
Rod Speed
Jules said:
It will, you watch.
to a few days after being opened up providing you're careful
about the environment in which it's done. That's long enough
to recover data off the drive (but forget using the drive long
term obviously is heads *will* crash eventually)
Not many drives fail in a way that needs the heads
replaced without gouging up the media in the process.
modern drives handle the calibration automatically during startup?
Depends on what you do about the platters. If you remove and
replace them, you have buckleys of getting them back the way
they were before you removed them as far as the eccentricity
of the tracks is concerned, because the tracks were written
on the platters after the platters were installed in the drive.
changes). I'd assume that track zero is found electronically, rather than
being dictated by any mechnical resting place of the head assembly.
Bad assumption. There's a reason you can hear a drive recalibrating.
Especially with flying heads.
Not necessarily, quite a bit of that comes from the design of the heads.
from the donor drive - those magnets are *strong* and likely something
You dont need to remove them.
The main problem is that many drives need to have the platters
removed to get the heads removed and you have buckleys of
getting them back the way they were before they were removed.
And most drives that need new heads have gouged up
the media in the process of the original heads failing.
Jules
No, usually once a month or so in order to recover data from drives with
sealed spindle motors that are suffering from stiction or bearing
problems. I just tend to leave them running once I've got everything off
just out of curiousity to see how long they'll last before they go crunch.
startup.
Umm, what servo motors? Long time since any hard disk used them...
Ahh, gotta love the trolls...
Jules
No, there is that - I'd assume that the OP has a good reason for wanting
to swap head assembly (i.e. they've ruled out that the problem isn't with
the logic board in the drive)
Depends on what you do about the platters. If you remove and replace
them, you have buckleys of getting them back the way they were before
you removed them as far as the eccentricity of the tracks is concerned,
because the tracks were written on the platters after the platters were
Absolutely - I'd assume they OP has a drive where they could technically
get the heads out without disturbing platters, otherwise things are
guaranteed to go horribly wrong :)
I don't know - most hard disk manuals seem to say that they'll do periodic
recalibration (or at least ones for high end SCSI drives do)
The main problem is that many drives need to have the platters removed
to get the heads removed and you have buckleys of getting them back the
heh heh, for sure - and I can't see there's any chance of getting the
platter stack apart and being able to put it back together again in order
to read existing data off! :)
If heads will come out without touching the platters then maybe the OP
should give it a go if they have a spare donor drive lined up - they can't
be any worse off. I've never heard of anyone actually trying this though
(let alone trying it and it working! :)
cheers
Jules
R
Rod Speed
with sealed spindle motors that are suffering from stiction or bearing
off just out of curiousity to see how long they'll last before they
go crunch. :)
You're thinking of stepper motors.
R
Rod Speed
Jules said:
for wanting to swap head assembly (i.e. they've ruled out that
the problem isn't with the logic board in the drive)
Its more likely he assumed the heads are
the problem but doesnt know that they are.
could technically get the heads out without disturbing platters,
You're doing a lot of assuming.
otherwise things are guaranteed to go horribly wrong :)
periodic recalibration (or at least ones for high end SCSI drives do)
Different matter entirely to the recalibration you can
hear when the drive cant read the platters properly.
getting the platter stack apart and being able to put it
back together again in order to read existing data off! :)
the OP should give it a go if they have a spare donor drive lined
up - they can't be any worse off. I've never heard of anyone
actually trying this though (let alone trying it and it working! :)
Yeah, because if the heads need replacing, they've
usually gouged up the media in the process of failing.
F
Folkert Rienstra
Say you, who admits to know no one who actually did it, including himself.
Yes, on bad sectors. The rest is just drive health checks during idle time.
I'll guess that IBM/Hitachi and Seagate don't make 'high end SCSI' drives
anymore then.
Well, that's _your_ problem.
there's any chance of getting the platter stack apart and being able
to put it back together again in order to read existing data off! :)
As if you ever tried.
Well, for that to happen it must have the heads parked at a parking rest,
obviously.
then maybe the OP should give it a go if they have a spare donor drive
lined up - they can't be any worse off.
Except for killing the donor drive without any gain.
So you haven't been around much, so what.
F
Folkert Rienstra
After they already have gone crunch once before you got them.
And none ever used servo motors to adjust head alignment, you simpleton.
Especially those that display their ignorance so fast and freely that
it is almost impossible not to make fun of them (i.e. ignore the bait).
Making you the troll, (in case you missed that too).
Ok thanks
the drive in question is an old quantum 5.1el so I suppose it has
1/possibly 2 heads and the arm can be rotated away from the platters
completely before pulling it out!? Now what about
aligning the magnets and sliding the 'new' arm over the platters...any
special tools etc.
P
Peter
Ok thanks
special tools etc.
No, just a steady hand. Practise makes you perfect.
