P
positivebalance41m
I have a unique situation where I require regulated 10VDC @ 10mA isolated
supply to run some control circuitry and the only available power sources
are 340VDC or 3 phase 220VAC (which can vary between 170Hz to 280Hz. This
has to be extremely low cost, reliable, easy for large scale manufacture,
and not require heatsinking of any components.
I am thinking to use a tiny 0.25VA 115VAC 60Hz transformer that I can get
from Mouser for USD$2.00. Simple 1/2 half rectify and filter. Then use an
NJR78L10 voltage regulator.
Any thoughts on an idea I am considering to use the very cheap 115VAC
transformer on 220VAC +/- 20% 200Hz, by placing a series Bilateral TVS
(some people know these by the name of Transorb, or back to back zener
essentially).
Since I only need an output of constant 10mA from the transformer secondary
(12.6VAC CT) and I don't care the output AC waveform is distored, I thought
this might work.
Unfortunately in trying to find a 220VAC transformer, the cost goes from
US$2.00 to US$7.00 so hence my motivation to be "unconventional" on this.
I know my transfomer losses will be higher at 200Hz compared to 60Hz but I'm
not concerned with efficiency as much as I am concerned with low cost and
reliable functioning.
Can anyone suggest the correct TVS voltage rating? Will the 200Hz pose any
specific problems for the 60Hz designed transformer that could be an
unpleasent surprise? I thought instead of a series TVS, to have a series
capacitor or even a resistor but the 220VAC frequency changes by about 30%
so any R/C ideas to my mind appeared to be too frequency sensitive...but
maybe I miss some clever ideas, component(s), or confirgurations. Perhaps a
shunt TVS and a series capacitor would ensure the transformer primary sees a
more constant 115VAC. I am guessing that on the primary side of the
transformer, there will only be about 1.2 to 1.8mA of ac current. That is
because I will have a fairly constant 12.6VAC at 10mA out of the secondary,
and I assume a few percent will go to core laminations magnetization
current.
Comments anyone?
THANKS
~TM
essentially).
this might work.
current.
Comments anyone?
THANKS
~TM
