Tinning of electronic component leads
Discussion in 'Hobby Electronics' started by Charles L, Apr 8, 2005.
  1. Charles L
    Charles L Guest
    I heard somewhere that the leads of common electronic components (resistors,
    capacitors, transistors etc), such as you might buy from Dick Smith
    Electronics are tinned with a lead based compound. Is this correct? Any help
    with this query would be appreciated.
    Charles L
  2. Alan
    Alan Guest
    You cannot buy any components from Dick Smith..
  3. Ken Taylor
    Ken Taylor Guest
    Solder is a tin-lead alloy (unless you use specifically lead-free solders),
    and that is what is (generally) used for tinning, so the answer is yes. You
    should assume any solder contains lead and use appropriate precautions.
    Ken
  4. KLR
    KLR Guest
    almost certainly Yes.
    almost any solder used in electronics at this time has some lead
    content.
    There are lead-free solders coming into use in Europe and such though,
  5. Phil Allison
    Phil Allison Guest
    "Alan" ...
    ** Their catalogue has the usual range of passives and semis.
    .................... Phil
  6. Phil Allison
    Phil Allison Guest
    "Charles L"
    ** Not quite - component leads are normally copper wire and the coating is
    a tin/lead alloy ( not a compound) ie solder. Solder typically has a lead
    content of 40 % to 60 %.
    The solder coating on a lead is quite thin and leads are trimmed short when
    mounted on a PCB - as a result far more solder is used to connecting them
    onto PCBs.
    ........... Phil
  7. Mr.T
    Mr.T Guest
    Those diodes and LED's I got the other day would indicate otherwise. It
    depends on the store I imagine.
    Powerhouses all stock components AFAIK.
    MrT.
  8. rowan194
    rowan194 Guest
    DSE stores may still have stocks of components, but they're in a big
    mess. A few days ago I needed a rectifier and a 470uF cap. I didn't
    need specific types, which is just as well... only about half of the
    trays with rectifier labels had anything in them (some were "cross
    contaminated" with completely unrelated components), and the 470uF tray
    was empty. I ended up grabbing a 680uF from a tray chock full of them,
    but that value isn't even in their catalogue any more! Of course the
    chick behind the counter spent 30 seconds peering at the wrong page,
    wondering why the little blue cylindrical thing with two legs didn't
    match any of the photos on it...
    This was just a quick trip to get a couple of things but it ended up
    being extremely frustrating. I wish Jaycar was closer than it is. :)
