P
PDRUNEN
Hi Group,
When would I select a gold plated connector over the standard tin plated?
Tnx
Paul
Tnx
Paul
If you need durability (many insert/remove cycles), consistent contact resistance over time andHi Group,
Tnx
Paul
Kevin said:In my experience, gold plating is very bad for frequently used contacts.
It scratches through and then corrodes very rapidly through electrolysis.
Lots of consumer battery packs had gold plated terminals in the 80s and
90s. They were a hassle. My one attempt to use a gold connector on a
bicycle light was a disaster too. In all cases the gold worked great
for about a week then needed daily cleaning with a tissue.
PDRUNEN said:Hi Group,
plated?
Tnx
Paul
It's sometimes advisable to have both sides of the connector the same metal,PDRUNEN said:Hi Group,
plated?
Kevin McMurtrie said:In my experience, gold plating is very bad for frequently used contacts.
Then the plating's not thick enough. Unforgiveable in this age when
gold's not worth a *shit* and hasn't been for 15 years at least!
Jim Yanik said:Yes,there's good gold plating,and there's BAD gold plating.
But tin grows whiskers that can short out the connector.
There is also good connector design and bad connector design. The
best plating won't make up for a connector that either (a) chews the
gold off, or (b) doesn't have enough sping in the female contact.
Jim Yanik said:Gold can be plated in varying hardness levels,too.
And tin is just as
susceptible to getting "chewed off",it's not that hard of a metal.Gold is
the best.
Jim said:[email protected] (Ken Smith) wrote in
ISTR you have to have the layer of nickel to get proper adhesion of the
gold.I'm no plating expert,just recalling(perhaps imperfectly) what TEK
engineering notes said about gold plating.
Metallurgists will know the right way.
Sven Hegewisch said:The nickel layer is a diffusion barrier for the gold which would
otherwise
diffuse rather fast into copper below.
