Timing Diagram software recommendations?
Discussion in 'Electronic Design' started by Nial Stewart, Mar 23, 2006.
  1. Nial Stewart
    Nial Stewart Guest
    When working on the low level design of FPGA modules I usually
    draw out a data path timing diagram showing what's happening
    on each sucessive clock cycle.
    I have a word 'template' I've been using to do this for years, but
    I often think it might be quicker/more permanent/better for
    documentation if I used a custom Timing Diagram drawing program.
    A very quick search shows these seem to be the options....
    1) Chronology's Timing Designer
    http://www.timingdesigner.com/
    2) Synapticad's Timing Diagrammer Pro
    http://www.syncad.com/ttd_main.htm
    Top of the range all singing all dancing design tools for complex
    board design/analysis. Quite complex to use (?) with a reasonable
    learning curve. Cost ~ $1500 for 1 node locked license.
    3) Timing Tool
    http://www.timingtool.com/
    This seems to be an interim solution, although it looks reasonably
    powerful. Probably not as difficult to pick up as 1) and 2).
    Cost - $795
    3a) Timing Tool Lite - a web based lower featured version of timing tool.
    I'd rather be working directly on my PC, although this is free.
    4) Timing Gen
    http://www.xfusionsoftware.com/
    Low end diagram drawing tool, this seems to be fairly new and doesn't
    include any analysis features. I'm not sure how flexible this is, they
    suggest importing things into Word to aid annotation etc.
    Cost - $129.95
    I think what I'm lookign for is something between 3) and 4). This isn't
    essential so I don't want to spend $800 on it, but I think I'd like
    something a bit more capable than Timing Gen although I haven't
    experimented with it much, and it would be hard to beat for the cost.
    Can anyone offer opinions on the packages above or and other suggestions?
    Thanks in advance for any feedback,
    Nial Stewart
    Nial Stewart Developments Ltd Tel: +44 131 561 6291
    42/2 Hardengreen Business Park Fax: +44 131 561 6327
    Dalkeith, Midlothian
    EH22 3NU
    www.nialstewartdevelopments.co.uk
  2. Bob Perlman
    Bob Perlman Guest
    Hi -
    I'm pretty happy with Synapticad. I can't comment on the latest
    version, as I dropped maintenance a while back: the verion of the tool
    I have (7.9-something) is plenty good enough.
    Doing timing diagrams with Synapticad is *so* much better than with
    conventional drawing tools. I'm convinced that I wouldn't do nearly
    as many timing diagrams if I didn't have Synapticad.
    Bob Perlman
    Cambrian Design Works
