timer
Discussion in 'General Electronics Discussion' started by john r, Apr 6, 2011.
  1. john r
    john r
    Apr 6, 2011
    Hi All
    I have just bought this timer to control a small 12v pump
    I can attach a fused supply to the terminal as indicated but what are the other terminals for ie where do I attach the negative for example, any help would be appreciated
    John
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    0V = "negative", "GND", or Common power supply (not to be confused with a real negative supply as in dual supplies)
    +V = Positive power supply
    NO = Normally Open relay contact (connect to pump - if it's to run only intermittently)
    C = Common relay contact (connect to +12V)
    NC = Normally Closed relay contact (not used here, unless pump is to run most of the time)
