Timer for a buzzer
Melkor6000
Mar 12, 2012
Mar 12, 2012
As part of a recent electronics project, I included a piezo buzzer, which I want to have buzz for about a second, and then stop.
I have tried using a 555 timer in monostable mode, but that doesn't work, since the voltage that triggers the buzz is continuous (I gather from other reading that a monostable oscillator only works when the lifetime of the trigger voltage is shorter than the discharge time.)
Is there a way to put something in-line with the buzzer, which causes a continuous voltage to become a ~1 second pulse? It would need to be able to do this time after time (a reset button is an option, since I have space for it on the console).
Thanks, and please respond if something is unclear in my question.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Place a capacitor between the "continuous voltage" and the trigger pin of the 555.
That way, whenever the voltage turns off, a brief pulse will set off the monostable.
See here. Note that you need a negative going transition to trigger the 555.
