Timer circuit
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
Hi all ,
I have been building many projects where I face a common problem while using a 555 delay circuit. The thing that I have noticed is that every time I switch the circuit off and switch it on again I get a different time delay than expected I.e I get the time delay as per calculations only for the first time . So in order to do that , I had a reset switch which I used to control a relay to short the + end of the capacitor to ground via a 10 ohm resistor. As it thought this might be a crude way of doing this, Is there any other way I can get this stored charge to back to zero?
Thanks in advance.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
If you are generating a pulse-train (i.e. the 555 is wired up in an astable circuit) then this is a feature.
You could try increasing the frequency and using a divider to divide the output by 256. This will cause the output to have a 50% duty cycle which may be a problem.
I've seen this used for long delays in an astable circuit too (the 55 is held reset when the divided output changes.
If you can give us some more details we may be able to suggest something.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
You could try using a CD4538. It is to monostables in one package is very simple to use and is reliable.
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
Thanks for the reply.
If there is a lot to be changed, please suggest me a alternate circuit /IC that will replace that without that defect. By the way I don't know to program.
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
Thank you so much for the response.
A humble request,if you can plz send me a circuit with CD 4538 that will not have this short coming.
Thank you.
AnalogKid
Jun 10, 2015
2,895
Jun 10, 2015
2,895
Please post your schematic.
It might be possible to solve your problem with a circuit modification.
Think about the question you are asking.
ak
Bluejets
Oct 5, 2014
6,938
Oct 5, 2014
6,938
I remember using an addition to the 555 circuit to give the same time at startup but will have to find it.
AnalogKid
Jun 10, 2015
2,895
Jun 10, 2015
2,895
Yes, there are two or three modifications to the standard timer circuits that will reduce this problem, but without knowing the circuit he is using it is just random speculation.
ak
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
ak
Sorry for the late response.
I have attached the circuit in my reply.
This is the circuit to monitor the heat rate ( it will display he number of beats per minute). So I used this 555 circuit to turn the output on after a delay of 1 minute.
In this circuit you can notice that I have connected the capacitor to the DPDT relay. This will disconnect the capacitors connection from the positive terminal and discharge the capacitor via a resistor (resistor connected to ground)when the reset button is pressed.
AnalogKid
Jun 10, 2015
2,895
Jun 10, 2015
2,895
There is nothing wrong with your reset approach. Just because it is not all solid state, that doesn't make it "crude". If it already is built and works, there is no automatic reason (inability to get parts, long term reliability, etc.) to change it.
BUT - that relatively gigantic timing capacitor's value will drift with both ambient temperature and aging. A more stable monostable approach is a high frequency oscillator and a divider. With a much smaller, 1%, metalized film capacitor, the circuit would be much more stable. With a crystal it would not need calibration. Look into the CD4060 and CD4521.
And, only because someone will say it, a PIC, arduino, etc. can do both the timing and the counting, reducing the other digital electronics to nothing more than a display driver.
ak
Karthik rajagopal
May 9, 2016
257
May 9, 2016
257
ak
Thank you so much for helping me .
