timer circuit
Discussion in 'General Electronics' started by Jeff Broner, Jul 23, 2004.
  1. Jeff Broner
    Jeff Broner Guest
    I don't know anything about electronics, but I'm willing to learn if this
    project is possible: I'd like to build a very compact timer that runs on AC
    115v 60hz. It would consist of a simple clock circuit that outputs to some
    kind of programmable logic circuit. This circuit would be programmed to turn
    a relay on/off at specific times of the day (it could be a one time
    programmable type of thing). My ideal design would be all solid state and
    fairly compact, like less that 1.5" (~ 40 mm) cube. What I'd basically be
    making is a lamp timer like the ones you can find at walmart, but much
    smaller and minus the digital interface. Is this possible, and if so how
    cheap could it be made? Any suggestions on manufacturers of the components?
    Thanks.
