Timed Toggle Switch
Discussion in 'General Electronics Discussion' started by Brighton, Sep 2, 2009.
  1. Brighton
    Brighton
    Sep 2, 2009
    I am looking for a timed toggle switch to insert into a pump application. The reason for the timed switch is a concern if the operator leaves the pump on it will over time burn out the seals and cause leaks. I am looking for a 15-20 amp small toggle that would shut down after a set time of around 15-30 minutes>.
