Timed switch - help (short question)
Discussion in 'General Electronics Discussion' started by goodenough63, Oct 14, 2011.
  1. goodenough63
    goodenough63
    Oct 14, 2011
    Hi, I need a circuit to switch off a current for around 60 seconds when triggered.
    I have purchased a 555 monostable switch, is this something that could work for this purpose?
  2. jackorocko
    jackorocko
    1,284
    Apr 4, 2010
    Yes you could use a 555 in "one shot" mode to drive something else like a relay or transistor to control the load.
    More detail if you expect help
  3. goodenough63
    goodenough63
    Oct 14, 2011
    ok thank you
    what i have bought is this
    http://www.maplin.co.uk/555-monostable-switch-kit-220009
    i have a cable with a low current at 12v constant.
    what i need is a cheap compact solution to switch this off for 60 (ish) seconds
    a variable timer option would be good.
    i dont have equipment for pcb production unfortunately
    is this maplins product above capable of one shot mode?
    thanks for the help
