Time Dealy Circuit
Discussion in 'Electronic Basics' started by Richard Harris, Jan 16, 2005.
  1. Hi,
    I need a circuit that activates on a 60 second delay, the input must be
    9v battery and the output device requireds 9v. Any one have a diagram for
    something simple like this.
    Is it posible to do this simply with a capacitor and some resistors?
    Thanks ever so much for your time.
  2. CBarn24050
    CBarn24050 Guest
    555 springs to mind.
  3. You can do this with an RC delay. One way would be to use a switch
    transistor, as follows:
    (look at this with a fixed-width font, or it won't make sense)
    On-Off
    / s d
    .--o o----o---------+^+-------------.
    | | |g |
    | 9V | | | |
    | o---------' | Your |
    | | | Circuit |
    '-------------o-------------------------'
    (created by AACircuit v1.28 beta 10/06/04 www.tech-chat.de)
    The idea is that when the switch is closed, the capacitor will charge up
    to 9V, and slowly decay down to 0. The P-MOFSET will turn on when it's
    gate at some point as the voltage decays. The voltage at which it turns
    on will be determined by the cap and resistor values.
    The problem with this circuit, through, is that the transistor will turn
    on slowly. Because of the fact that you want a long delay, the
    transistor will stay in it's 'linear region' for a long time, causing
    the voltage across your circuit to come up quite slowly.
    A better way is to use an opamp (or comparator) to sense the delay and
    turn on a drive transistor with. Here is a rough sketch
    On-Off
    / P-MOSFET
    .-o o---o-------o------------o---------+^+-----------.
    | | --- 47uF | | |
    | | | | | .-----o-----.
    | | 1MEG | | | | Your |
    | 9V .-. | |\| | | CIrcuit |
    - | | | ___ | >--------o | |
    | '-' o-|___|-o -|+/ | | |
    | | | 1MEG | |/| ___ | | |
    | | | '--------|___|-' | |
    | | | | 10MEG '-----o-----'
    | | | | 1.8MEG | |
    '---------o-------o------------o-----------------------'
    When you throw the ON switch, the 47uF cap will be dragged up to 9V, and
    will gradually decay down to 0V. The 1MEG potentiometer is used to
    adjust when the P-MOSFET comes on. Depending on the leakage of the 47uF
    cap and the mosfet, it's possible that the thing will decay more quickly
    than expected, so the potentiometer can be used to adjust the time
    delay. You can get LM324 chips from Radio shack (it's an opamp). There
    are 4 opamps on it, so if you use that chip, make sure you disable the
    other opamps by tying the - leads to 9V, and the + leads to 0.
    Otherwise, it might cause some kind of oscillations. If you can get a
    comparator instead, you may need what's called a 'pull up' resistor on
    the output. Look at the package. If so, a 1k resistor from the output to
    9V (after the swtich, of course) will do the job.
    The P-MOFSET should have an off voltage of something like 3V, since the
    LM324 will only get up to about 7V, and it should be completely off. The
    ON voltage of the P-MOFSET must be less than 9V. My guess is that all of
    the P-MOFSETs you can get at radioshack will fall into this category.
    The voltage at the - input of the opamp will be near
    V = 9 * exp(-t/RC).
    Where t is the time after the switch is closed.
    You can probably get the parts for a few dollars.
    Regards,
    Robert Monsen
    "Your Highness, I have no need of this hypothesis."
    - Pierre Laplace (1749-1827), to Napoleon,
    on why his works on celestial mechanics make no mention of God.
  4. You could easily adapt one of these three delay circuits I posted a
    few years ago for a 'Delayed On Motor':
    http://www.terrypin.dial.pipex.com/Images/DelayedOnMotor.gif
  5. Thanks for that, I have another question, On your circuit diagram the
    capacitor will charge up and then the mosfet will switch and the circuit it
    will power will come alive. What happens when the capacitor discharges, will
    it then stop the circuit being powered then be cut off. Will this form of
    delay then be more like a flasher. Charging and discharging?
    Thanks for your time and patience.
  6. No, initially the MOSFET will be off. It's only after a minute or so
    that the MOSFET will turn on. It turns on when the voltage between the
    'source' lead and the 'gate' lead gets to be about 8V. It's off when the
    voltage is less than about 3V.
    It won't turn off again until you turn off the entire circuit.
  7. What type of capacitor should I use, electrolytic?
    And will the capacitor and resistor in the circuit have and influence to the
    output voltage of the circuit? i.e I can use a high ohm resistor 1-2M and a
    small capacitor like a 220uf and all will be fine.
    Thanks alot, sorry Im very new to electronics.
  8. The formula to use to compute the voltage at the mosfet gate after a bit is
    V = 9 * e^(-t/RC)
    where t is time, R is resistance, and C is capacitance.
    You haven't said which circuit you are going to use. If you are going to
    use the simple circuit with only the P-MOSFET, then the IRFD9120 starts
    to turn on when the gate somewhere between 2V and 4V below the source
    lead, which is at 9V. So, given a 1M resistor and 220uF capacitor
    (electrolytic is fine), then if it's 2V, you have
    t = -ln(2/9)*1e6*220e-6
    t = 17 seconds.
    For 4 volts, you have
    t = -ln(4/9)*220 = 98 seconds
    Thus it will start turning on between 17 and 100 seconds. You can't tell
    beforehand any more accurately. These are the limits given in the datasheet:
    http://www.alldatasheet.com/datasheet-pdf/view/INTERSIL/IRFD9120.html
    It gets worse. The time it takes to turn on the thing completely depends
    on your load. If you are powering something that draws 9mA (like a 1k
    resistor) it will turn on in something like 9 seconds. That means the
    voltage will start at 0, and will increase over a period of 9 seconds to
    9 volts.
    However, if you are powering a load that takes 10x as much current (a
    100 ohm resistor, for exaple) then it can take up to 30 seconds to turn
    on. That means the electronics you are powering will be erratic for up
    to 30 seconds. Not good.
    The second circuit I posted, the opamp circuit, doesn't have this
    problem. You can set the timeout experimentally using the 1MEG pot to be
    exactly 60 seconds. Once the timeout is complete, the MOSFET snaps on,
    because the comparator turns on completely as soon as the voltage drops
    to equal the voltage at the pot's trimmer.
    Regards
    Bob Monsen
  9. Thanks, Ill have to try your op amp circuit out then, could you give me the
    pin information for your circuit design. I found the LM324.
  10. Look for yourself. Here is the datasheet:
    http://www.national.com/ds/LM/LM124.pdf
    Regards,
    Robert Monsen
  11. Does this look good.
    On-Off
    / P-MOSFET
    / s d
    o-o o---o-------o-------------o---------+^+-----------o
    | | --- 47uF | |g |
    | | | | | .-----o-----.
    | | 1MEG | | LM324 | | Your |
    | 9V .-. | |\4 | | CIrcuit |
    --- | |<----------------2|-\ | | |
    - | | | ___ | >1-------o | |
    | '-' o-|___|-o--3|+/ | | |
    | | | 1MEG | |/11 | | |
    | | | | | ___ | | |
    | | | o---------|___|-o | |
    | | | | 10MEG '-----o-----'
    | | | | 1.8MEG | |
    o---------o-------o-------------o-----------------------o
    1 = Output 1
    2 = Input 1-
    3 = Input 1+
    4 = V+
    11 = GND
    PS Ill send ya some free op amps if this works.
  12. Yes, I think that will work.
    Ok, let me know.
    Regards,
    Robert Monsen
  13. Thank you so much, your a genious, works almost perfect.
    If ya send me your address ill post ya some LM324's, are you in the UK?
    I have one more requirement for this circuit, if you can help.
    The problem is when power is conected the circuit being powered by the time
    delay circuit gets power for a fraction of a second. I need it to only get
    power when the time delay has passed. No current can flow until the time
    delay has passed, this is critical, is there away to stop this breif power
    surge.
    Thank you agian.
  14. I've got enough LM324s, but thanks.
    The issue with the initial power surge is that the LM324 isn't getting
    power until after the P-MOSFET, causing the mosfet to be on briefly.
    Put a 1k resistor between the output of the LM324 and the gate of the
    mosfet. Then, put a cap, like a 0.1uF ceramic cap, between the gate and
    the source of the mosfet. When the power comes on, it should drag the
    gate up, keeping it from turning on until the LM324 wakes up. If it
    still has the brief blip, add more resistance, maybe 10k.
    Regards,
    Robert Monsen
  15. peterken
    peterken Guest
    problem is the "unknown" behaviour of the opamp during power-on, thus a
    typical error in design overlooked by most
    in this circuit you can only handle it by slowing down the fet
    method would be to use a series resistor towards the gate, and a cap from
    gate to ground
    this again would slow down your output a bit, but might be reasonable
    compared to thhe surge now
  16. That solved the problem perfectly. I have discovered a new problem theo,
    I needed a way to drain the 47uF capacitor when the circuit is switched off,
    so I used a switch that when off connects the positive battery terminal to
    the negative capacitor pin. This drains the capacitor ok but for some reason
    there is a breif serg to the output circuit. Can this be solved are am i
    stuck.
    Thanks again.
  17. I am not understanding the issue. Why do you want to drain the
    capacitor? What is the problem you are solving?
    Regards,
    Robert Monsen
  18. no problem, I have fixed. Thanks again, by the way are you in the US?
Similar Threads
Loading...
