Tilt sensor
Discussion in 'Hobby Electronics' started by Guest, Feb 14, 2005.
  1. Guest
    Guest Guest
    Where can I find "tilt sensor" with analog and/or digital output indicating
    the tilt angle with better than 1 degree resolution?
  2. Jamie
    Jamie Guest
  3. The Analog Devices ADXL202E is probably the most popular device around.
    Fairly cheap too.
    I've used it as a three axis tilt sensor, and <1 deg resolution is
    easily achievable. Digital PWM output, or analog output with a filter.
    http://www.analog.com/en/prod/0,2877,ADXL202,00.html
    Dave :)
  4. Boris Mohar
    Boris Mohar Guest
    How did you temperature compensate it?
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
  5.
  6. MC
    MC Guest
  7. Fred*
    Fred* Guest
    Analog Devices ADXL103
