Tilt Sensor Project
Discussion in 'Sensors and Actuators' started by wfrench, Oct 5, 2012.
  1. wfrench
    wfrench
    Oct 5, 2012
    I'm trying to design a circuit/product for my degree that checks that an angle is correct. EG. an incline of a slope/ladder etc is correct (say between 25 - 30 degrees) and if it is outside the limit a buzzer goes off. Maybe even have a display to show the angle. I'm trying to do this on a tight budget, i have looked into tilt sensors but the only cheap ones I have seen are the trigger ones with either a ball or tilt switch, is there anything programmable or customizable?
    Does this make sense, I am competent in soldering and know the basics, could someone put me in the right direction, any existing circuits out there?
    Regards,
    Will
  2. wfrench
    wfrench
    Oct 5, 2012
    Do I need to use an accelerometer?
  3. Laplace
    Laplace
    1,252
    185
    Apr 4, 2010
    Perhaps you need a single-axis inclinometer? http://en.wikipedia.org/wiki/Inclinometer
    Do you need to read an angle or just sense a limit? If it is just to sense a limit then you could hang a half disk from a pivot point. The disk will always hang straight down. Make it from clear plastic, mark the limit with black paint, and sense the limit region with a phototransistor.
  4. CDRIVE
    4,960
    652
    May 8, 2012
    It would be low tech but a series of mercury switches and logic gates would work.
    Chris
  5. wingnut
    wingnut
    242
    9
    Aug 9, 2012
    As you turn a pot-log the V varies. Attach this to a meter and you get analog measurement of the degree.
  6. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    define cheap. if you got a wii nunchuck remote it has a tilt sensor in it. they run for bout $10 on ebay. there are a heap of alternatives but that one is the easiest one I know of
Similar Threads
Loading...
