Tilt Angle between two LDR
Discussion in 'General Electronics Discussion' started by zackfair, Dec 12, 2015.
  1. zackfair
    zackfair
    9
    Dec 12, 2015
    hi, i'm am engineering student and i'm running for my project right now. Lecturer ask me to find "tilt angle between to two LDR". he said just use two LDR and differential op-amp. how i'm supposed to conduct the experiment and i don't know how the circuit was? can anyone help me cause i'm really need the method for this experiment? thanks a lot
    p/s: sorry for my bad English
  2. Martaine2005
    Martaine2005
    3,224
    883
    May 12, 2015
    Hi zackfair,
    Your English is good, but the question is not very clear. Do you mean the angle at which they will turn on?
    The datasheet for the particular component will give that information.
    davenn likes this.
  3. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Yes please explain more.
  4. zackfair
    zackfair
    9
    Dec 12, 2015
    I forgot to tell that i'm running for analog project basically. I thought it was something like in the picture as my lecturer explained to me. When the LDRs received light, the difference voltage that they produced will receive by op-amp. Then, from the op-amp, tilt angle will be determine. It is tilt angle of light?
  5. Martaine2005
    Martaine2005
    3,224
    883
    May 12, 2015
    I think I understand, but wait for a "proper answer"....
    The op-amp is used as a comparator and compares two input voltages. As LDR1 detects more light, the resistance drops and voltage increases to the op-amp.
    As LDR2 has less light, the resistance rises and voltage drops..
    It's the op-amps job to compare the two and keep a 'stable' input.
    When you tilt (move) the light source above the LDRs, or move it side to side, the voltages will be rising and falling.
    I am not sure if that answers your question or not..
    Martin
    zackfair likes this.
  6. zackfair
    zackfair
    9
    Dec 12, 2015
    Yes, it is!! I just can't figure out how the circuit was and how to get the angle. Can you help me?
  7. Martaine2005
    Martaine2005
    3,224
    883
    May 12, 2015
    To be honest, I don't know what is meant by 'angle'..
    If you can explain that, somebody can help you..
    Martin
  8. Harald Kapp
    11,014
    2,506
    Just a guess: look up "solar tracker" or "sun tracker". Here is an example. Note that for good tracking you will have to place an opaque shield at 90 ° between the two LCDs so that one LDR receives more light than the other when not aligned to the source of light.
    Tha fios agaibh likes this.
  9. Tha fios agaibh
    Tha fios agaibh
    2,131
    721
    Aug 11, 2014
    Only one op amp?
    Something simple like this would go on/off with a narrow angle. But not very functional.
  10. zackfair
    zackfair
    9
    Dec 12, 2015
    No, he not said just use only one op amp. Hmm.. I need to to ask him by face-to-face back what he want actually as he don't reply my email.
  11. GPG
    GPG
    452
    66
    Sep 18, 2015
    Any power supply restrictions?
  12. zackfair
    zackfair
    9
    Dec 12, 2015
    No, I guess.
  13. GPG
    GPG
    452
    66
    Sep 18, 2015
    Bipolar supply, connect ldrs in series junction to amp+ set gain using - input. Angle the ldrs to left and right
  14. zackfair
    zackfair
    9
    Dec 12, 2015
    sorry sir, can I have an image?
  15. GPG
    GPG
    452
    66
    Sep 18, 2015
    If you mean a picture,no. If you mean a circuit, that's your job
  16. zackfair
    zackfair
    9
    Dec 12, 2015
    thank you sir for your help
  17. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    You really need to attend 3 more years of your Bachelors Electronics classes before you can entertain the possibility of designing the type of circuit you request.
  18. Martaine2005
    Martaine2005
    3,224
    883
    May 12, 2015
    Zackfair,
    Your lecturer did not explain to you as in your diagram!!
    Open loop and closed loop are very different.
    Without feedback, the op-amp has no idea what you want.
    Inverting and non invertinting are also different.
    Depending on the external circuitry, it can simply turn off and on, or output the diffence of the two and use that.
    Here is a video I have been watching for months......It doesn't matter how many times I have paused/played this, I understand the moment.....After that I forget!!
    Martin
