tick tick tick
Discussion in 'Electronic Repair' started by Janice, Jul 21, 2005.
  1. Janice
    Janice Guest
    Hello
    I have a problem that I can't find the problem to and woundering if you
    guys can give me a heads up on what to look for.
    Problem: 20 inch Sharpe Tv, Model # CR20T69
    I push the on switch and it ticks and ticks and ticks.
    Sounds Like the relay in the set.
    Any suggestions would be great!
    Thanks a bunch in advance
    Janice/in training
  2. kip
    kip Guest
    What have you done so far in diagnosing the fault ?
    Tell us more
    kip
  3. Janice
    Janice Guest
    Well I checked the horizontal ouput coil and seems to test well.(no opens)
    i check the high voltage caps and that seems to be within the tolerance
    (mfd)
    Checked Horizontal output trans and that is good as well.
    I am in the process of checking more capacitors for leakage in the high
    power section. Also checked the basics (fuse, relay, etc)
    Did a ring test on the flyback and that is good also.
    Also checked for opens in the horizontal deflection coil.
  4. Jim Yanik
    Jim Yanik Guest
    Depending on how old the TV is,it probably is bad electrolytic caps,perhaps
    in the power supply. You need a ESR meter to check them,or just replace
    them all.
    The next thing would be a shorted rectifier diode.
  5. Janice
    Janice Guest
    TV is 10 years old, but now I discovered that the ticking noise is
    comming from the flyback.... I tested all of the caps in the high
    voltage section and all diodes are good when tested.... I'm thinking
    maybe a cold solder joint perhaps....
    Thanks for the info....much appreciated
    Janice/in training
  6. kip
    kip Guest
    If you suspect a cold solder joint why dont you look for it ???
    kip
  7. sofie
    sofie Guest
    Janice:
    Are you absolutely certain that the horizontal output transistor is good.
    Take it out of circuit and test it again. Also check the flyback
    derived B+ circuitry for shorts or faulty components.
    If all of that checks out go back and test the power supply carefully for
    proper regulation and other faulty parts like shorted diodes, open
    resistors, open traces, bad solder joints, etc.
  8. b
    b Guest
    remove the HOT and power the set up. if it goes into standby, chances
    are the horizontal deflection has a problem and your power supply is
    probably Ok. Failing that, a short on one of the voltage lines is
    possible, eg. fried vertical IC. who knows?
    -Ben.
  9. Jim Yanik
    Jim Yanik Guest
    the "tick-tick" sound could be the power supply starting and re-starting
    over and over due to bad filter caps(ESR),very common in older sets,or a
    shorted diode causing an excessive load and triggering the primary current
    limit,making the PS re-start over and over.
    The electrolytics ESR would be the first thing I'd check (after looking for
    burnt parts) if I didn't have a schematic to check the PS voltages against.
    Dick Smith Electronics has a nice ESR meter,VERY useful,as a kit for
    ~$50USD,perhaps even less. It's also available assembled elsewhere.
    I have NO connections to DSE except that I own one ESR meter and love it.
  10. Guest
    Problem solved.
    Bad driver transistor (opened) in horizontal osscilator circuit.
    Also noticed and resoldered a possible hair crack on the primary of the
    horizontal transformer.
    Thanks for all the help guys
    much appreciated...............
    janice
  11. JANA
    JANA Guest
    This is very common, that the HV multiplier, flyback, and horizontal output
    transistor may have to be changed. Also, there may be some damage in the
    power supply as well. Also, an ESR test of all the caps in the related areas
    should be verified. There may be other collateral damage.
    These sets can be complex to service. A strong background in TV servicing,
    and having the proper service information is a great asset when servicing
    these sets.
    JANA
    _____
    Hello
    Janice/in training
  12. clifto
    clifto Guest
    Ungrounded aquadag. Broken picture tube. Pinhole in HV lead.
  13. Assuming the description of the problem above is complete, ignore him.
    It's probably an overload on the power supply - possibly a shorted HOT.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    ignored unless my full name is included in the subject line. Or, you can
    contact me via the Feedback Form in the FAQs.
  14. kip
    kip Guest
    Kip did not write that...
  15.
