TI CCS problem: file operation
Discussion in 'Electronic Basics' started by Davy, Oct 13, 2005.
  1. Davy
    Davy Guest
    Hi all,
    I always work on VC and now I want to port my code to TI CSS.
    I read the CCS manual, and confused with file operation.
    I want to read data from a virtual data source. And write to another
    virtual data file.
    Does TI CCS support standard C file operation like "fopen" and "fread"
    and "putchar"?
    Any suggestions will be appreciated!
    Best regards,
    Davy
  2. Chris Carlen
    Chris Carlen Guest
    Which DSP platform?
    For the one with which I am familiar, the C2000 platform, CCS has "probe
    points" and other goodies that allow you to input/output data from
    files. This is in the development phase. For real file IO in the real
    application, then of course some sort of hardware file storage mechanism
    and associated drivers would need to be in place.
    Spend time working through all their tutorials. Then you will have the
    overview of what features are available and how to use them.
    Good day!
    ________________________________________
    Christopher R. Carlen
    Principal Laser&Electronics Technologist
    Sandia National Laboratories CA USA
    NOTE, delete texts: "RemoveThis" and
    "BOGUS" from email address to reply.
  3. Davy
    Davy Guest
    Hi Chris,
    Thank you for your help!
    I use the C55 platform. And shall I write the driver when I want to use
    " probe points"?
    Best regards,
    Davy
  4. Chris Carlen
    Chris Carlen Guest
    No not at all. The purpose of probe points is to let you inject or
    eject data under the debugger (or I suppose under the simulator as well)
    with a great deal of ease, ie., without having to write any drivers.
    In a simulated application, or in an app under development where some
    system components (and their drivers) responsible for supplying data to
    the DSP or doing something with data generated by the DSP are not yet
    available, the DSP developer would be able to get work done by having a
    way to virtualize the data flow. The probe points allow this. But they
    are implemented by the debugger, not by lines of code which call some
    stdio library for instance. They allow you to develop the data
    processing algorithms in the absence of the code that actually IOs the
    data. Later of course you will have to implement the code that will
    interact with whatever hardware to IO the real data.
    But the way to get started understanding all this is to invest the time
    working through all the tutorials, giving at least a brief read through
    the most relevant user guides and app notes, then starting to write some
    experiment apps.
    Good day!
  5. Randy Yates
    Randy Yates Guest
    Hi Davy,
    Contrary to several others' opinion, I prefer file I/O over
    probepoints.
    I found file I/O via the standard C libraries does work
    but not as expected on the C54x platform. The problem
    has to do with differences in, e.g., the minimum addressable
    unit on the C54x being a 16-bit quantity rather than the
    8-bit char that is available almost everywhere else.
    I've written some "hook" routines that translate the C54 file
    I/O operations into the ones we've come to know and love.
    You're welcome to them - email me at .
    Put the string "TI File I/O" in the header so I don't trash
    your message as spam.
    --Randy
  6. john
    john Guest
    I have done exactly the same thing, Randy, and I prefer file I/O to
    probe points. I use utility routines on the Matlab side and CCS side
    that understand the TI formats. I have found it to be a reliable way to
    get data onto and off of the DSP -- once you understand the formats and
    limitations.
    Probe points are nifty, but TI needs to simplify their configuration.
    There are too many steps and menus. With file I/O, I can put a project
    on the shelf for a year, come back to it, and I'm in business quickly.
    With probe points I have to returh to the documentation, navigate the
    bugs, deal with changes to the IDE, and worry about obsolescense.
    One thing the file I/O method is not is fast.
    John
