Thyristor diagrams in wrong place or not?
Discussion in 'General Electronics Discussion' started by Electro132, May 16, 2013.
  1. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    HI,
    I need some help deciphering this circuit on how it works and whether the components are in the correct place. It's from this website:
    http://www.doityourselfgadgets.com/p/coilgun-knowledgebase.html
    I found out that the thyristor they placed has G (far right) in the negative (something that A should be in since A is the centre of the thyristor). But A is placed in the Output according to the diagram so i'm abit confused with both diagrams. Any help is appreciated.
  2. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Also need to know how to attach a screw on capacitor to the circuit as i've never done one before.
    Cheers
  3. (*steve*)
    25,496
    2,837
    You use big thick wires.
  4. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Thanks Steve. By the way, i found out that the circuit on that website works so nothing needs to be changed. I only need the other larger circuit diagram explained as it is in german.
    Cheers
  5. CDRIVE
    4,960
    652
    May 8, 2012
