thrustmaster t300rs wheel dead no power
Discussion in 'Troubleshooting and Repair' started by mohanad, Dec 3, 2016.
  1. mohanad
    mohanad
    12
    Dec 3, 2016
    hi
    i have a thrustmaster t300rs ffb wheel for pc i had it for 6 months and all of a sudden it died with no power at all
    i cracked it open and found that the internal power supply is giving (30 volts) instead of (25 volts).
    i replaced it with a laptop power supply with 25volts and 2amps max but still not getting any power and the power light is off.what component might be burnt ?
      File size:
      342.8 KB
      1,436
      File size:
      277.2 KB
      1,061
  2. Alec_t
    Alec_t
    2,940
    799
    Jul 7, 2015
    Welcome to EP!
    Looks to me like the negative terminal of that big 2220uF cap hanging off the board has a dry joint with the board, with charring around it and the adjacent black connecting wire. Also, the big electrolytic (C88?) at bottom left seems to have leaked/cooked (or is that just shadow?).
  3. davenn
    davenn Moderator
    13,802
    1,941
    I see that regularly on boards ... it appears to be well soldered on the other side
    That ground wire joint does need checking
    looks like lots of solder flux
    @mohanad please show a better photo of around that cap mounted to the side of the board
    and BOTH sides of the board
    chances are that the fault is elsewhere
  4. mohanad
    mohanad
    12
    Dec 3, 2016
    t
    thank you for the reply,i have high res photos of the board but when uploaded it gets compressed,how to get around that ?
  5. mohanad
    mohanad
    12
    Dec 3, 2016
    thank you,i will take close ups og that section,do you know how to upload high res photos this site compress it to a small size?
  6. davenn
    davenn Moderator
    13,802
    1,941
    just do closer in images but make sure you keep your focus
    the resolution u used on the other pix isn't a problem
    programs like IrfanView are great for simple resizing and compressing image files
  7. mohanad
    mohanad
    12
    Dec 3, 2016
      File size:
      311.1 KB
      468
      File size:
      361.5 KB
      337
  8. mohanad
    mohanad
    12
    Dec 3, 2016
    are these good ?
  9. davenn
    davenn Moderator
    13,802
    1,941
    great quality but wrong end of the board ;)
    want to see both sides of the board of that top right section where that capacitor is bent over to the side of the board
  10. mohanad
    mohanad
    12
    Dec 3, 2016
    here you go
    i posted 5 photos no.3 is the other side
      File size:
      216.5 KB
      549
  11. davenn
    davenn Moderator
    13,802
    1,941
    sorry, I missed that, the pix in the thread were of the other end LOL
    it all looks good
    so the real problem is ... what has failed ???
    can you indicate where you were measuring that 30V and how you think it is supposed to be 25V ?
  12. mohanad
    mohanad
    12
    Dec 3, 2016
    it has an internal power supply written on it output:25 volts and 2 amps when checked with the voltimeter it says 30 volts
  13. mohanad
    mohanad
    12
    Dec 3, 2016
    do you see the plug with the 4 pins,this is where the power supply goes,when connected to the pc the usb sends 5 volts through this plug which goes to the power supply which activates a switch on it (triac) which make the current pass through to the board and the wheel powers on
  14. davenn
    davenn Moderator
    13,802
    1,941
    in this pic of yours I see a little solder tail going off to the side .... see the red arrow
    probably not a problem as it probably hasn't penetrated the PCB coating, but gently scrape it off anyway
  15. davenn
    davenn Moderator
    13,802
    1,941
    ummm OK
    a higher voltage ( open circuit voltage) tends to indicate that it is not being loaded down by the circuit it supplies
    The other thing it could be is that the PSU itself has failed and is just putting out unregulated voltage
    sooooooo show us the PSU
  16. mohanad
    mohanad
    12
    Dec 3, 2016
    as i told you i used i laptop psu with 25v and 2amps and hoocked it directly to the board through the 4 pin connector (only used two pins) still i get no power
  17. davenn
    davenn Moderator
    13,802
    1,941
    OK so the PSU is unregulated, it could quite easily show 30V when it's not under load
    on this section with the PSU socket .... 1 and 2, which is the 25V pin and which is the control pin ....
  18. davenn
    davenn Moderator
    13,802
    1,941
    trying to go beyond those first few components without a service manual or at minimum a schematic is going to make a repair somewhere between difficult and impossible
  19. mohanad
    mohanad
    12
    Dec 3, 2016
    1 and 2 are the control pins the other two are for 25v,too bad i thought it was fixable i have two of these and both are broken,thank you for your help
  20. mohanad
    mohanad
    12
    Dec 3, 2016
    Can we say it is normal to have a higher viltage under no load condition ? if this is the case then may be one of the caps is bad ?
    Whats happens if a cap is bad ?does cut or break the circuit ?
