Three pole regulator
Discussion in 'General Electronics Discussion' started by guyorf00, Apr 28, 2012.
  1. guyorf00
    guyorf00
    Feb 3, 2012
    The three pole regulator is at http://avstop.com/AC/apgeneral/regulation.html
    According to the conventional theory current is flowing from the positive terminal of the armature down through L1 to ground or back to negative terminal of the armature. L2 flows down through any combination of C1/C2/R1/R2. Then current flows trough L3 and splits to go up through L4 and down trough L5 to the ground and back to the negative terminal of the armature, and up through L4 if C3 is closed to the load and back to the ground to the negative terminal of the armature and also to charge the battery whose negative terminal is also connected to the negative terminal of the armature. Does this seem right or do the arrows mean something else? And why is there a conductor between the voltage regulator and the current limiter?
    Guyorf 00
  2. davenn
    davenn Moderator
    13,107
    1,696
    The circuit explanation given in the link with the circuit diag is not too bad to understand.
    The arrows on the coils (L1 to L5) which are all part of a solenoid system are important because they indicate the direction of the windings and in this case show that some of the windings are wound in opposite directions on the solenoid core, which is as stated in the text.
    You do realise that these solenoids are switching the contacts C1, C2 and C3 very quickly as they respond to variations in voltage and current flow ?
