three phase rectifier voltage issue
Discussion in 'Power Electronics' started by alal, Jun 21, 2019.
  1. alal
    alal
    6
    Jun 21, 2019
    I captured an output voltage waveform of the three-phase rectifier system. Could anyone help me understand what might be the cause of the little spikes?
  2. Minder
    Minder
    3,104
    664
    Apr 24, 2015
    Is this supplying any load, or just a 3ph rectifier?
    What is the source of the 3ph?
    Where are you referencing it to, the wave form is not a normal rectified pattern for 3phase.
    The should have a 120deg overlap for every cycle.
    M.
  3. alal
    alal
    6
    Jun 21, 2019
    It has dc crane and dc led lights on the system. The crane load is on and off. When the led lights are on, the problem exaggerates. I'm trying to figure out the source of the problem, the rectifier or the led driver. The source of the 3ph is from a three-phase ac transformer.
  4. Minder
    Minder
    3,104
    664
    Apr 24, 2015
    I added a edit in the mean time, as I said the wave form does not look normal other than the spike.
    M.
  5. Minder
    Minder
    3,104
    664
    Apr 24, 2015
    It appears to be more 1phase than a typical 3 phase output.
    M.
  6. alal
    alal
    6
    Jun 21, 2019
    I think the correct waveform should look like this. It seems it's missing every other peak.
  7. Minder
    Minder
    3,104
    664
    Apr 24, 2015
    You should be getting a 360deg approx 5% ripple sitting on the top.
    What is the nature of the rectifier and where is your reference point from?
    M.
  8. alal
    alal
    6
    Jun 21, 2019
    The time division is 7.95 on the x-axis. I counted the peaks based on this time.
  9. Alec_t
    Alec_t
    2,973
    804
    Jul 7, 2015
    Are you sure the polarities of all the rectifier diodes are correct?
  10. alal
    alal
    6
    Jun 21, 2019
    I think the polarities are correct. I run a simulation with the wrong polarity, the waveform does not look like the measured.
  11. alal
    alal
    6
    Jun 21, 2019
    I found out it is actually half controlled rectifier, so 3 diodes, 3 SCRs. The waveform is normal.
