Thomson TV start up problem: led flashing sequence
Discussion in 'Electronic Repair' started by Ocean Tragic, Jul 16, 2004.
  1. Ocean Tragic
    Ocean Tragic Guest
    My TV does not start but the LED flashes in a particular sequence
    The tube appears to start for a split-second three times.
    Then the LED flashes twice
    then a pause
    then the LED flashes seven times
    then a pause
    then a pause
    then a pause
    then a pause
    then the TV goes into standby mode.
  2. Art
    Art Guest
    Model & chassis of your flasher?? Any diagnostic results other than pressing
    the power button??
  3. Ocean Tragic
    Ocean Tragic Guest
    model is 28VK26UW
    not sure about the chassis unless 434/ICC17GB means anything
    thanks for your help
