Thomson 28WF25U
Discussion in 'Electronic Repair' started by ::::Jim Mason::::, Oct 8, 2006.
  1. Hi
    My Thomson 28" television has failed to start up after coming back from
    holiday. Model is 28WF25U.
    Standby light comes on then flashes amber 3 times then red twice followed
    by 7 red flashes. This repeats for three times then the standby button
    stays on and the TV will not respond.
    Is this a repairable fault or is it time to upgrade?
    Thanks in advance for any help.
    Jim
  2. Jim Land
    Jim Land Guest
    Is this the ICC17 chassis? If so,
    Thomson TV Model: (ICC17 Chassis)
    Standby led fault codes and meanings list / standby led flashes then
    pauses
    Code meanings are as follows: 10 = child lock mode, 11 = timer mode, 14 =
    there is no response from Iv01, 15 = there is no response from IS40, 20 =
    bus access prohibited by software, 21 = bus data line held low, 23 = bus
    clock line held low, 25 = switched 5v supply missing, 26 = crt is not
    warming in the allotted time, 27 = deflection failure more than three
    times, 28 = IF01 guard voltage (pin 8) exceeded, 34 = no response from
    the nvm chip IR03, 36 = incorrect address passed to bus handler, 37 =
    unexpected level on NMI line (power fail), 41 = bus data line not
    recoverable
    --http://www.e-repair.co.uk/tips.htm
  3. I belive it is.
    So it looks like 37. Thanks for the quick response.
    Jm
  4. Apologies - 27.
    Jim
