Thinking of a windpower setup
Discussion in 'Home Power and Microgeneration' started by Rockin Ronnie, Dec 12, 2004.
  1. I live in the country and have a 1 1/2 acre lot half of which is treed.
    I am on top of a hill. I have not checked average wind speeds but I
    would suspect that it is enough to justify windpower.
    I am thinking of a low power 400+ watts system to give me what I would
    need in the event of a winter power outage (Nova Scotia). I was browsing
    through the Air-X site and found what I was looking for.
    Assuming that I would spend $1000CDN for the wind generator, how much
    more would I need to spend if I wanted to tie the wind generator into my
    existing electrical system? For example, tower, inverter, batteries,
    electrical connections etc.
    Or, direct me to a site where I can make a list of all of the things
    that I need.
    Ron
  2. Guest
    Hi Ron.
    Wind speed is not the most important factor. Consistency is. I live
    where it is thought to be fiercely windy. When it blows, it is
    memorable. But it seldom blows enough to be useful.
    I have an Air 403 turbine, and mostly it is my $500 weather vane.
    Some howling nights it earns its keep, but they aren't often. Take
    lots of data before buying.
    The turbine does some howling of its own, by the way. Mount it
    downwind from your house. It will need to clear obstructions by a
    fair bit, like 25 feet. Tower. I wouldn't mount it on the roof -
    vibration and mechanical racket.
    Here, sun is my powerful source, though maybe not in N.S.
    Charles Foot recommended a voltmeter mounted where it will grab your
    attention. That as a minimum. I use Tri-Metric integrating charge/
    discharge meters on both my systems. They cost, but tell so much
    more than a voltmeter.
    Tom Willmon
    near Mountainair, (mid) New Mexico, USA
    Net-Tamer V 1.12.0 - Registered
  3. Gymy Bob
    Gymy Bob Guest
    Since nobody else answered your question.
    What you need is a grid-tie unit. A unit that will syncronize with the
    incoming frequency and lock to it.
    Here comes the bad news. Somewhere between $6K-$12K Canuck buck.
    What they don't tell you is that this stuff will never pay off at Canadian
    power rates usually unless you live to be 140 years old and have no
    maintenance costs. Not gonna' happen. It's an interesting hobby.
  4. Vlad
    Vlad Guest
    My suggestion doesn't satisfy your needs but if I could install a
    windpower setup I would stay way from batteries.
    I use electricity to heath my water. As we know that accounts for a
    substantial share of domestic needs.
    I would design a system that would preheat the water going into my hot
    water tank. With 2 or more elements that can be switched to a number
    of series/parallel combinations ,dynamically tuning to the most
    efficient load to my generator.
    The system could be expanded to feed a hot water heating system and
    one light on the living room that would only be ON when all other
    requirements are satisfied.
    One should remember that all the power that goes into a lamp of any
    kind it's converted into heat. Lamps are very good heaters. As
    heathers they give us light at zero cost.
    Vlad
  5. Vlad
    Vlad Guest
    I know, that is why I said "
    I was just fishing for opinions on the subject.
    Vlad
