Thin Backlighting Options - EL? LCD?
Discussion in 'Electronic Design' started by Adrian, Oct 22, 2004.
  1. Adrian
    Adrian Guest
    I would like to have text advertising on an automobile, and have the
    visibility of the advertising controlled electronically (i.e. you can turn
    it on and off). When off, it is to be as invisible as possible. Cost
    effectiveness is also a key factor.
    Ideas thus far:
    - Electroluminescent Sheeting, cut to the desired shapes or backlighting
    some vinyl
    - LCD Sheets (do they even exist??)
    Any ideas?
    As always, many thanks in advance!!
  2. Clarence
    Clarence Guest
    Electroluminescent Sheeting is not likely to be very invisible if you expect to
    see it when it is on. You can only get about .034 W per CM^2 so it doesn't
    show up in sun light well.
    The colors are usually pale green (With out a filter) and the sheet, when off
    is off white.
    There are people who make the Car signs. The ones I have seen were about 14 x
    20 inches.
    IN theater lighting I have seen Electroluminescent Sheeting up to 30 by 60
    inches. But the power requirement is substantial.
  3. Nemo
    Nemo Guest
    Ah, cost effectiveness is liekly to be a problem, as this sounds like a
    custom job...
    OLEDs and PLEDs are black when not active, which may be easier to blend
    in with a car's paint. However, they will struggle to compete with
    sunlight and are not generally available yet, though custom
    implementations are beginning to appear in mobile phones.
    Perhaps the most cost effective solution would be arrays of LED's. These
    can be pretty bright these days, cost effective, and quite visible in
    sunlight as you will have seen on motorway signs.
    The back-end driving of these will likely be a fairly complex customised
    solution though. It'll need a microcontroller, power supplies etc...
    See "LED Business Sign" thread in this newsgroup for more on this.
