Thick or Thin Film Resistors
Discussion in 'General Electronics Discussion' started by Rajinder, Jul 2, 2017.
  1. Rajinder
    Rajinder
    526
    9
    Jan 30, 2016
    I wanted to ask if I have a thick film resistor with the following specifications:
    Case size 0603
    Tolerance +/-1%
    Voltage 50V
    Value 10K
    Temp coefficient 100PPM/C
    Application is for ultrasonic level measurement
    Can I replace this with a thin film resistor with a like to like spec? Or are there other parameters to consider.
    Best regards,
    Raj
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Yes you can as long as the product is not used in a high humidity environment as thin films have a greater tendency to absorb moisture. They are a superior resistor over thick film in many ways, but are normally more expensive.
    Adam
