D
Dejan Durdenic
I need to keep a PCB on the fixed temperature level. I will do it
with Peltier element attached to the aluminum housing which will
hold the PCB. The problem is - what should I use to fill the box
to have optimum heat transfer? It would be nice if the stuff can be
(easily) removed later in the case some service is needed...First I
thought of filling the box with thermal grease used for attaching
heatsinks to transistors/IC's, but it would be impossible to remove
it later... Any suggestions?
Dejan
Dejan
