Thermostat that works below zero F
Discussion in 'General Electronics Discussion' started by us214760, Jan 3, 2010.
  1. us214760
    us214760
    Jan 3, 2010
    I need a thermostat that, when switched into heat mode, will work even when the ambient temperature is well below zero degrees F. My current Honeywell won't work below 32 degrees F. Any brand & model suggestions?
  2. awright
    awright
    10
    Oct 10, 2009
    Are you referring to a home heating thermostat? Are you talking about 32 degrees indoors at the thermostat? Why won't your Honeywell work below 32 degrees ambient? What model thermostat do you have and what is its operating principle (bimetal, mercury switch, semiconductor sensor)? Give us a little more detail.
    awright
