Thermometer Circuit
Discussion in 'General Electronics Discussion' started by alexlongaretti, Sep 17, 2017.
  1. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    Hello Guys,
    I found this circuit. It should tell the user if the water is too cold, to hot or the correct temperature to bath a baby.
    At the moment, this circuit only tells the user is the water temperature is too hot, or below the chosen temperature. So at the moment, this circuit only has 2 outputs.
    Is there any way of adding another output to the circuit, so that it can also warn the user if the water temperature is too cold?
    Thanks in advance.
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    You want a window comparator circuit to do that.
    Arouse1973 likes this.
  3. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    Can you please explain me what that is?
  4. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    Sorry, but I'm not an expert in this sector.
    Is this a complete circuit by itself, or should I integrate it in my previous circuit?
  5. Bluejets
    Bluejets
    5,025
    1,048
    Oct 5, 2014
    When my kids were babies, we used our elbow. No batteries, failsafe and accurate.
  6. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    But this is a school project.
    That's why I'm asking
  7. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    It would be easier to make one from scratch than to modify the circuit you have.
  8. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    And do I have to make a window comparator circuit in order do do that?
  9. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Yes.
  10. BobK
    7,682
    1,688
    There is nothing mysterious about a window comparator. It is just one comparator for the high end and one for the low end.
    Using a standard comparator IC with open collector outputs, the two outputs can be wired together to a single pullup resustor to give a low signal when out of range and a high signal when in range.
  11. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    Hello guys,
    Do you think the attaches circuit suits well for what I need?
    Thanks in advance
  12. BobK
    7,682
    1,688
    If this is a school project, aren't you supposed to do the work, or at least understand the circuit that you "borrow?"
  13. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    I AM understanding it.
    I just wanted someone else's opinion.
  14. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    What is the IC? Does it have a ground connection?
  15. alexlongaretti
    alexlongaretti
    8
    Sep 17, 2017
    The IC is the following: TCA965
    Yes, it should have a ground connection, as you can see here.
    For more info you can Google this: TCA965 Datasheet
