Thermocouple Sensor Design
Discussion in 'Sensors and Actuators' started by jrd78ep, Mar 23, 2013.
  1. jrd78ep
    jrd78ep
    13
    Mar 21, 2013
    Hello Guys…I am making a sensor design using 6 pairs thermocouple as a thermal sensor around the machine. I want the output goes like this…if only 1 over 6 thermocouples triggered a yellow led lit. And if more than 1 thermocouples triggered then a red led lit…Thanks a lot for sharing your ideas…
  2. (*steve*)
    25,496
    2,837
    What do you mean by "triggered"?
    Do you mean when a thermocouple junction exceeds a certain temperature?
    There are some chips that will read the temperature from a thermocouple and allow it to be read by I2C (for example). These could be connected to a microcontroller that would handle the LED switching based on the readings from the 6 thermocouples.
  3. jrd78ep
    jrd78ep
    13
    Mar 21, 2013
    Thanks for the reply...yes you're right about "triggered" --something like the temp exceeds as normal...
    Can you please name the ic so i can search it in google and also the microcontroller...Sorry im new in electronics...thanks.
  4. (*steve*)
    25,496
    2,837
    MAX6675 is the one I had in mind, however an AD595 is another option (with a totally different interface)
    You could interface either with (say) an Arduino or a PicAXE.
  5. jrd78ep
    jrd78ep
    13
    Mar 21, 2013
    Thanks Steve...i'll try to study the ICs first and then do the actual :)
Similar Threads
Loading...
