R
Richard Rasker
Hello,
I'm designing on a thermal control system based on Peltier elements to
create a presettable, highly stable temperature for testing newly developed
semiconductor/optical devices.
The Peltier element is placed between two aluminium surfaces; the top
surface is a disc, slightly larger than the Peltier element, and has a
precision temperature transducer attached to it. The bottom surface is
larger, and is bolted to a big aluminium heatsink. The whole structure is
encased in a very rigid foam, with the aluminium top disc cemented flush
with the surrounding foam surface.
The problem is that different sorts of objects are routinely clamped or
pressed on to the top disc for testing; this has the risk that the Peltier
element inside is exposed to an unevenly distributed mechanical stress,
causing it to break. This has already happened on several occasions, and
with a price of some $50 each (not counting building the "thermo-table" in
the first place), this problem needs solving.
I've though about a springy metal construction which presses the Peltier
element gently against the top disc, but I can't come up with something
both small and thermally conductive enough.
The only other thing I can think of, is to use some sort of compressible,
termally conductive material which will even out the mechanical force
dstribution. I tried the normal silicone pads, but these still have a high
thermal resistance when not very firmly compressed, which plays merry hell
with my temperature control loop, amnong other things.
Does anyone know of any more foamy or soft-rubbery substances out there with
good thermal conductivity? Typically, I need some ~0.2 mm (1/100 of an
inch) compressibility without a huge increase in force.
Thanks in advance for any tips, best regards,
Richard Rasker
Richard Rasker
