I have this thermal switch from a Gemmy fog machine that I have had for a number of years. I recently rewired it and figured out in the process that the thermal switch in it is probably bad. It should read about 50mΩ when closed but when I disconnect it and test it with my meter it reads anywhere from 0.2 to several hundred Ohms. So obviously I should replace it, but I do not know the switching temperature of it. On the top ceramic part it is marked with "KSD301" which is just a generic part number. On the bottom surface it says "B240" and "CM". Does this mean a switching temperature of 240'C?
