L
Lauri Alanko
I have some leds in 8 mm through-hole packages, rated for 0.5 W,
maximum steady current 100 mA. The legs are extra wide at the top, but
there is no other built-in heat sink. These are chinese cheapos from
ebay and no proper datasheet was supplied.
I intend to lay these out in a lattice on a stripboard, but I'm
worried about thermal issues. How closely can I position the leds? Do
copper strips provide enough additional heat dissipation area, or do I
need to etch and drill a PCB? At the very least I suspect I should
leave the legs sticking out from the board instead of cutting them.
Also, is there some way to measure the temperature of the led to check
if heat dissipation is sufficient?
Typical through-hole leds are low-power so heat isn't much of an
issue, and typical power leds are SMD and have dedicated heat sinks.
0.5 watt through-hole leds seem to be in a grey area and I can't find
much information on them. Any advice is appreciated.
Lauri
Lauri
