The way to do FIR filter.
B
boki
I found there are two method to do FIR.
A. find the coefficient from fourier series.
B. Window method.
My thinking about A.
1. Use fourier series to contribute a desire filter curv(ac response)
2. find fourier series
3. convolution signal with series
4. Get the FIR.
I am correct?
Thank you very much.
Best regards,
Boki.
B
Bob Masta
B. Window method.
4. Get the FIR.
I am correct?
Almost. You find the Fourier series for the
filter, then do an inverse Fourier transform to
get the time-domain impulse response of the
filter. That impulse response is itself the
FIR tap weights.
But unless you need a lot of control over the
exact shape, the window method is a lot
simpler.
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
