The Pioneer Effect and the Unified Field Theory
Discussion in 'Electronic Basics' started by bkh99, Feb 5, 2008.
  1. bkh99
    bkh99 Guest
    The two Pioneer spacecraft which were launched in the early
    seventies,
    have both been decelerating at a constant speed as they rise in the
    sun's gravitational field (the rate of constant deceleration is
    equivalent to the speed of light multiplied by Hubble's Constant).
    It
    is obvious that such a correspondance could not be attributed to
    random
    causes, such as gas leaks, but rather new physics are required.
    The behavior of objects that fall or rise in gravitational fields are
    inversely related, in that a falling object begins slow and then
    accelerates, while a rising object begins fast and then decelerates.
    An example of the latter is the release of a weather balloon which
    attempts to rise at full velocity but is prevented from doing so by
    atmospheric drag. The weather balloon then decelerates at is rises
    in
    the gravitational field until finally it stops and then parks in an
    orbital state at a certain height. This behavior is similar to that
    exhibited by the Pioneer craft.
    Think of the total potential velocity of the Pioneer Spacecraft as
    being somewhere just below the speed of light. When an object is
    'conserving momentum' as it rises in a gravitational field and the
    result is deceleration and a loss of velocity, this means that the
    object would require 'more momentum' if it was to maintain its
    previous
    velocity. When an object which is rising in a gravitational field
    and
    is 'conserving momentum' and it decelerates and then loses velocity
    what this implies is that at the same time its total potential
    velocity
    is increasing. Here we can see the reason for the relationship
    between
    Hubble's Constant (used to measure redshift) and the rate of
    deceleration of an object rising in a gravitational field. Einstein
    was incorrect to insist that speed of light is a fixed constant in
    all
    frames of reference (any space-time) but it must be the case that the
    speed of light is relative (space dilation, time dilation, and
    velocity
    dilation all occur in harmoney). It is this error that prevented
    Einstein from successfully discovering the Unified Field Theory which
    would unify gravity and electromagnetism during his lifetime.
    The solution to this enigma of 'conserved momentum' resulting in
    'deceleration' is to understand that everything is relative, and that
    includes 'momentum' since one given 'momentum' results in a lower or
    a
    higher velocity in different frames (with no exchange of energy
    taking
    place an object will acelerate and fall or decelerate and rise).
    The explanation for this behavior is found in a proper
    electromagnetic
    explanation of Archimedes principle. The universe is a giant energy
    field and what we call 'space' is a three dimensional creation of the
    magnetic field (which is a three dimensional pheonomenon). 'Space'
    dilates according to the Inverse Square Law (the energy field is more
    dense closer to a source and then becomes less and less dense the
    further away you move from the source). Given these inherent density
    restrictions you can only put so much 'energy' into 'so much space'
    and
    where this restriction is violated displacement occurs. It is this
    tight binding that exists between 'energy' and 'space' which then
    results in 'motion' and 'velocity'.
    Another mistake that Einstein made was to dilate space (stretch it
    out)
    closer to the field source. This dilation was required if there was
    to
    be a slower clock in a gravitational field while at the same time the
    speed of light was to be kept an invariant constant. It is only when
    we dilate space-energy (make it less dense) the further we move from
    the source and allow the speed of light to be a variable constant
    (relative) that we are then able to discover the unified field theory
    (unifying gravitation and electromagnetism). Motion is simply
    displacement (an unallowable energy state) and what we think of as
    momentum is merely a density function (the greater the density of the
    energy in a closed energy system, the more forceful the displacement,
    the greater the velocity).
    Think of a weather balloon. It expands at it rises. It also
    decelerates and eventually parks and maintains an oribt. What this
    tells us is that even though no energy transfer is taking place, the
    weather balloon is not 'conserving its momentum', but rather it must
    be
    losing momentum because it decelerates as it rises in the
    gravitational
    field. We also see that the weather balloon experiences the effects
    of
    dilation in that it expands. We also know that 'hot gas' expands,
    which is also a density function, and that hot gas then rises in the
    gravitational field (it is to dense, it is displaced, it rises). Now
    as an object rises it experiences a relative loss of momentum
    (relative
    in that this loss of momentum occurs without an actual transfer of
    energy taking place). This occurs because of relativistic spatial
    dilation which becomes greater the further you move away from the
    center of the field. This dilation then results in a lower density
    since the amount of energy now contained in an expanding space is
    lower. The displacement decreases and the result is less momentum
    and
    deceleration.
    In a similar way when an electromagnetic wave rises in a
    gravitational
    field it red-shifts. It does not red-shift because it is 'losing
    energy' to the gravitational field. This was another one of the
    compounding errors made by Albert Einstein (the result of keeping the
    speed of light a fixed constant). The light red-shifts because it is
    following the requirements of the Inverse Square Law. It is becoming
    'less energetic' so that it has a lower frequency and a longer
    wavelength. At the same time the law of the conservation of energy
    requires that energy never be lost or created, it can only be
    transferred. In this case the energy is 'transfered' to 'momentum'
    and
    teh speed of light increases as it red-shifts. There is nothing
    mystical or magical about this process, it is just the logically
    following consequence of the light being forced to dilate as it moves
    into less dense regions of the energy field.
    Even though the speed of light is a variable constant, it makes no
    difference, for the average speed of light between two points always
    works out to be 300,000 kilometers per second, so no one notices the
    variance. Think of it this way. Let's assume that the speed of
    light
    was '10'. The speed of light as it bounces off some satellite in
    space
    is 5, 10, 15 as it rises and then it is 15, 10, 5 as it descends back
    to earth, for an average speed of '10', Therefore even though the
    speed of light is relative, the light from an object '4 light years'
    away from earth would still seem to take '4 years' to reach us, and
    so
    no difference is ever noticed by any observer in any frame of
    reference
    you might want to choose.
    More discussion of this issue can be found at the following URL.
    http://www.awitness.org/unified/index.html
    Or as an 'e-book' in the form of a zip file.
    http://www.awitness.org/unified.zip
    Some satirical discussion of 'lighter than air balloons' and
    Einstein's
    matter based theory of gravity can be found here.
    http://www.awitness.org/unified/pages/tautology.html
    A proposed experiment to test the predictions of the Unified Field
    Theory can be found on the following page.
    http://www.awitness.org/unified/pages/pioneer_experiment.html
  2. Bob Masta
    Bob Masta Guest
    Huh? Wherever did you get the idea that the Hubble constant has
    anything whatsoever to do with solar gravitation?
    Bob Masta
    DAQARTA v3.50
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Scope, Spectrum, Spectrogram, FREE Signal Generator
    Science with your sound card!
