The Northeast US Needs our help
Discussion in 'Electronic Design' started by amdx, Mar 31, 2011.
  1. amdx
    amdx Guest
    Pray for Global Warming tonight when you go to bed.
  2. John - KD5YI
    John - KD5YI Guest
    Party for Global Warming tonight when you get home.
  3. amdx
    amdx Guest
    Is a Party for Global Warming akin to a Rain Dance?
    Mikek
  4. John - KD5YI
    John - KD5YI Guest
    Sure. Any excuse for a party.
  5. amdx
    amdx Guest
    Oh, but John, that's weather, not climate. ;-)
    Mikek,
  6. But it's the 2nd most snow on record. (65' is the record)
    Just like the Warminist's would preach.
    Cheers
  7. amdx
    amdx Guest
    There's always someone that likes the extremes, down here in
    Florida, there are people who can't wait till it's 95 degrees with
    90 % humidity.
    Mikek
  8. Rich Grise
    Rich Grise Guest
    Nah - all that white powdery stuff on the ground is denialist propaganda.
    Rich
  9. Rich Grise
    Rich Grise Guest
    Probably not - sometimes the rain dance works. ;-)
    Cheers!
    Rich
  10. MrTallyman
    MrTallyman Guest
    Sixty-five feet is NOT "the record", dingledorf!
  11. BlindBaby
    BlindBaby Guest
    No. It is a coin toss. You should have said "sometimes the raindance
    and a rain event end up coinciding.
  12. MrTallyman
    MrTallyman Guest
    There used to be glaciers there!
  13. PeterD
    PeterD Guest
    So far, so good... Only about 2 to 3 inches, just pray it stops!
  14. PeterD
    PeterD Guest
    Not any more they don't... NH, for example, has moved well out of the
    Demoncrat sphere of influence! There are, unfortunately, a few libtards
    left however.
  15. 95 degrees F and 90% humidity at the same time never occurred in any
    official weather station readings anywhere in USA.
    95 degrees F at 90% humidity means a dew point of about 91.5 degrees F,
    which exceeds USA's record dew point of 90 F.
  16. John - KD5YI
    John - KD5YI Guest
    If you are out in it, that's close enough.
  17. amdx
    amdx Guest
    Good to know, I'll stop using those numbers.
    I can't find a good site for records with humidity ( unless I want to spend
    $99)
    Can I get away with 95* and 80% humidity? :)
    Mikek
  18. Dew points exceeding 80 F at official weather stations in hot humid
    areas of USA are not common. At 95 F, the dew point is 80 F when the
    humidity is around 62%. At 90 F with dew point of 80 F, the RH is
    about 71%.
    Go ahead, during heat and humidity season, have a look at:
    http://www.weather.com/maps/maptype/currentweatherusnational/
    uscurrentdewpoints_large.html?collection=localwxforecast
    And at:
    uscurrenttemperatures_large.html?collection=localwxforecast
    And at a water vapor pressure table.
    Or, check the temperature and relative humidity of any city or zip code
    at weather.com or at accuweather.com. (My guess is that results not at
    a weather station are interpolated.) Check anyplace when you know they're
    stinking hot and humid.
