Except when it doesn't suffice. Sometimes its a naive view in that some
people when told that will believe it to be a fact when its not. Just like
ohms law is not a fact. Its a law that breaks down under certain conditions.
When people are just learning about these things they tend to be reluctant
to question. So I think it does everyone better if instead of trying to
state things as fact they are stated in the right context. (the context of
the right level of approximation for the job)
Yes. And rightfully so. In the absence of a specific request for
the microscopic, the macroscopic explanation will generally suffice.
If it doesn't, then the onus is on the querant to ask for more
detail. You seem to think that everyone wants to know the minutiae
of "why", and that's just not the case. In this instance the OP
asked for an explanation of why a noisy switch causes a counter to
count falsely, and the answer is: "Because the switch contacts make
and break many times before they settle down, causing multiple
transitions at the counter's clock input."
But the OP did ask for such and explination and I tried my best.
"or if it's because of the very rough
surface (microscopically-speaking) of the switch contacts, were the metal
molecules grinds (and possibly flexes) together, during switch activation?
since he brings in this microscopic level I can only assume he wants a
corresponding answer in the microscopic. (wether it is relvant to engineers
is irrelevant to me. He ased a question and I would answer it in his context
the best I can. Its not my job to question his reasons why he wants to know
this as I assume he has a better understand of his motivations than me. )
This can be shown to be true by using a mercury-wetted reed relay or
switch in place of a conventional switch. Doing that will result in
precisely one count made for each make-break cycle of the switch.
That suggests, to me, that the reasons you cited for the miscounts
(the electric field attracting or repelling the contacts, for one)
are flawed, since the very mobility of the mercury film would
certainly cause it to be more affected by that field than a big mass
on the end of a spring would be.
Because when you *tell* someone they might think that that is the answer and
only answer. Then this propagates arrogance. Those people then grow up tell
someone else the "fact" and everyone thinks its a fact. Then comes along
some guy that questions it and he's jumped on by everyone else. Its sorta
like how some laws are. Someone creates a law for a specific reason and
then many years down the line the reasons are forgotten and the law is
enforced even though its original reason for existing makes it invalid. But
it is enforced because people cannot think for themselfs(most people). They
don't question authority because they are afraid. To many people think facts
are a popularity contest. Life just doesn't work that way.
Again, the issues I tend to have with you guys is that you seem to think
that what you think are facts must be facts for everyone else. This is not
the cause and I think you guys are smart enough to really understand that
but its just easier to act like everyone has the same set of facts. But the
point is that just because you believe something as fact doesn't mean you
should state it as fact to someone else. I believe that it is a
fact(ofcourse its more of belief) that "god" does not exist. I do not state
this as a fact when talking to other people though and I accept there
opinions as long as they do not try and make it a fact for me. When they
try and make me except there facts they better prove it to me and not just
try and force feed it to me. This, to me, is exactly what you guys try and
do. You force feed people your "facts" when in reality they are not facts at
all(usually). Actually nothing is fact so we shouldn't force feed anything
to anyone else. We present the evidence and let the other person decide. If
they come to a different conclusion then so be it. Its not our job to get
everyone else to believe what we believe. Why? Because facts are not a
popularity context. Majority does not rule logic or facts. So many people
believe this(Specially religious people) that its disgusting. Some people
think that if they can get enough people ot believe what they beieve then it
will make it true. I don't think you guys believe that but many times you
act that way. Else you wouldn't get mad when someone disgree's with you or
asks you to explain yourself.
You seem to be saying that when it's convenient for you to use the
macro view you will, but that no one else is allowed to.
no, for all I know I could be completely wrong. I do have to think I know
something though as then I would be quite useless. I don't know everything
and I'm not even close. I could also be wrong in everything I say. I have a
minor in physics and have taken quantum mechanics, I have a degree in math
and have taken over 200+ credic hours. Does this mean anything? Maybe...
maybe not. I have forgot a great deal of what I have learned and could have
easily gotten things confused. But sure, there are somethings I believe
very strongly about just like you do. BUT I rarely see you guys give any
evidence to support your claims. I will happily give my evidence and
reasoning if it is asked for in a way that isn't belittling. Ultimately I
want to learn and share knowledge and not get into childish games. Sure it
happens and sometimes maybe its my fault but that is not the goal for me. I
do not come to this newsgroup and offer help when I can feed my ego. I come
here to learn and thats pretty much it. Who knows what I can learn by
helping someone else out. Maybe it will lead to things that I can't imagine
now.
Sure. What else am I suppose to do. Well, maybe I am. But I do have
experience with you, Larkin, and several others that do the same sorta
things so its not such a bad approximation. Ultimately we will run into
issues like this because thats life and its full of contraditions. Its not
a narrow-minded view as it is simply being lazy I cannot possibly talk about
all of you guys seperately and describe all the reasons I have come to my
conclusions(would be a waste of time to do so). Similarly as you make the
macroscopic approximations to make things easy I have to make things easy.
If you asked "Why do you feel this way about me" then either I would tell
you the reasons(and if they are not proof enough for you then you could ask
me and then I would try to find the proof. Maybe I would learn that it was
my fault and a made a mistake or misinterpreted something. Who knows) or I
would tell you I don't have time to waste on it(cause unfortunately theres
only so much one human being can do).
So true, I might be guilty of it and sometimes I am guilty of the exact same
things you guys do. I have no problems admitting it. Its not right but
sometimes it a necessary evil.
Do you know that just because you have no proof of the existance of
something does not mean is is false? We know by the incompleteness theorem
that there are things that are even unprovable. We know also that we can
prove somethings about something but not find any specific examples. (We
might be able to prove that there exists something but actually never be
able find it.)
Quantum mechanics also tells us that time can be reversed(and must be) so
maybe one can find a way to uncook and egg. This is assuming QM is true and
we do not know htat 100% but it looks like it. So sure, I don't know how to
uncook an egg. But I don't know how to do a lot of things but that should
not stop me from trying to learn.
Maybe. That is not my goal as I'm just trying to express my point of view.
In the first place, If I want to make an all-encompassing statement
and not back it up with proof, that's my business. I'm certainly
not bound by _your_ rules, and if you have a problem with the
statement, then the burden of proving it false is on you.
Sure. I cannot change that. I hope that you understand that it is not as
productive, atleast I hope you would reason to that because I believe the
alternative is much better. We can learn a lot from history and while
history is not always right it does help a lot. I cannot make you do
anything but only offer evidence that its probably not a good idea to think
like that. The evidence simply might be wrong or wrong to you(some stuff is
just relative and we can't escape it).
Well, the very act of disagreeing with someone is saying: "I think
you're wrong" or just plain old: "You're wrong", which means that
you think you know more about it than they do, so if you disagree
with the way people post in this newsgroup that means that you know
better than they do about how they should post. Don't you agree?
No, not necessarily. I do see your point but if I say someone is wrong its
more "I think your wrong, please explain why." Its not as polite to just say
"Your wrong" and I try not to say it like that. What I really mean is
"EXPLAIN WHY!!". Why do I say it like I do? Because if I say "Your wrong"
then most people that actually understand why they think they are right are
going to present the evidence if they want to explain. Atleast thats what I
do. I also know that if people get angry when they are told they are wrong
then it probably means that they don't really know why they believe what
they do. (else why get angry. If a 2 yr old kid comes up to you and says
"Your stupid. The earth is flat!" do you get mad and punch the kid in the
face? I would hope not.)
"If there is good counterlogic involved" means that you get to be
the judge of what is and what isn't good counterlogic, so you get to
be in the favorable position of deciding whether you're right or
wrong by deciding whether your opponent's logic is good or not
regardless of whether your opinion is right or wrong. Handy, no?
But this isn't a chess game. We are not trying to play king of the
mountain. We are hear to learn, no?
Not true. I wouldn't love being questioned in a hostile manner by a
person who is frustrated by his inability to understand the answer
to the question and is trying to prove me wrong because of his
inability to admit to being wrong.
I agree. But I do believe that I rarely question people in a hostile
way(saying "Prove it" is not hostile). I only get that way when someone does
or has tried to force feed me there garbage and I have found out from much
more reliable sources that they were wrong.(maybe the sources were wrong but
I have to believe someone).
Several of the problems I have had with "you guys" is that I have asked a
question about something and I was told something that may or may not have
been true. I have had contradicting sources and so I ask you to explain your
reasoning and evidence and instead I get jumped on. When that happens I do
not like it at all because now that means I will not learn anything about it
except by going somewhere else. It also seems to point that either someone
doesn't want to share there knowledge(they only want to dictate) or they
don't have the knowledge(so they pretend). In either cause it means I will
not learn anything from them any farther.
I think I'd be more of the chopped liver than you guys. I think you guys are
normal, probably pretty intelligent people but have lived in a hostil
enviroment that makes you a little to rough for me. I'm like a shark and I
can smell a drop ego a mile away. Sometimes I do over react and sometimes I
do let my own ego take control. This is not my goal. I'm only human just
like you guys. But what I do know is that when things become childish that
nothing important will probably come out of it. I understand that you want
to be treated with respect and that you have worked hard to learn the things
you have but you have to understand that I'm not the type of person that
takes anyone elses logic or knowledge on faith(even if its at my own
perile). I do this because I like to learn for my self. Just don't take it
the wrong way. If I sound like a kid sometimes its because maybe I am.
Sometimes I let my ego take control and all that. Again, I'm only human. I
think the main goal, whatever the problems is ultimate to learn(sometimes I
wonder why I think this way as it can be quite frustrating ;/). Anything
that gets in the way is a distraction.
I suppose. The problem is that there is no king without someone to clean the
toilets.
Jon
