So, I have managed to build an overdrive pedal, complete with a real stomp switch and a LED that lights when the effect is active.
The only thing left to figure out, is how to include an A/C plug that, when plugged into an adapter, cuts off the 9 volt battery power, and runs on the AC adapter instead.
I guess I need to find a schematic for it. Also, does anyone know what the female plug is called that would sit in the pedal, so that an AC Adapter can plug into it? I'll need to buy those and wire them in.
Thank you
Thank you
