Krpyton-ite
- Dec 19, 2014
- 1
- Joined
- Dec 19, 2014
- Messages
- 1
I currently do not have much experience in the realm of electronics except for an electronics class I took last year so please forgive me if I come across as ignorant.
In the process of planning out a circuit I wanted to use I found that I needed two diodes with a reverse biased breakdown voltage around 2-3 megavolts. They don't need to be very fancy. They just needed to hold current back unless the voltage is over a certain amount. After searching the internet for a while the best I have been able to find is a diode with a breakdown voltage of 800kV.
So my question is: Are diodes with this high of a breakdown voltage even made? And if so where would I find some?
If it is important to know, the forward biased current would only be in the milli to micro-amp range.
Thanks for any advice you can give.
