The electronic control grid of magic.
Discussion in 'Electronic Design' started by CoreyWhite, Dec 19, 2007.
  1. CoreyWhite
    CoreyWhite Guest
    Computer technology all runs on an electronic control grid. Just take
    a look at the iMac. I can't escape free wifi in my appartment, the
    computer has microphones and cameras. All designed to capture energy
    and broadcast the radiation outwards. It is a matter of relativity.
    Einstein got the nobel for the photo-electric effect, but they keep
    the science top-secret. The photo-electric effect just happens when
    metals conduct light into electricity. If you have ever noticed,
    metals also create red-hot light when you heat them up. So there is a
    parallel between magnetism & electricity, and light and matter. It's
    all connected. Quantum electron scanning microscopes are just arrays
    of metal detectors plugged into computers that take super sinsitive
    pictures. The trouble was that they found on a chemical level they
    couldn't observe matter without changing its chemical nature with
    these scopes. So from that technology they broadcasted a signal from
    space using a huge electron scanning telescope. According to
    wikipedia metal dectors are just like radar, and create electric
    connections that generate energy as well as detect it. So once the
    electron telescope began broadcasting a macro field, they created a
    vortex in consciousness that linked spirits into circuitry. Designing
    micro-electronics is just like understanding chemistry, you just have
    to understand the harmonic mixtures of matter & energy. So you see
    the mind vortex can do so much other magical things nobody knows
    about. By embedding tight electronic circuitry into props and
    gimicks, you can create the illusion of sleight of hand & magic that
    appears totally real. They can actually teleport and move things on a
    macro scale, and alter nature with the right antennas to the electron
    scanning grid. It is all just naturally a part of nature. The
    underlying consciousness that links matter and energy together. The
    spirit of the ethers.
  2. PeterD
    PeterD Guest
    They have drugs to treat your condition now...
  3. My first observation was that drugs CAUSED his condition.
  4. You are so lucky that you dont live in the Steam era, all those pipes
    underground, all that heat invading your body, and no aerogels.
    Just buy a bit more tinfoil
    martin
  5. Androcles
    Androcles Guest
    : Computer technology all runs on an electronic control grid. Just take
    : a look at the iMac. I can't escape free wifi in my appartment, the
    : computer has microphones and cameras. All designed to capture energy
    : and broadcast the radiation outwards. It is a matter of relativity.
    : Einstein got the nobel for the photo-electric effect, but they keep
    : the science top-secret. The photo-electric effect just happens when
    : metals conduct light into electricity. If you have ever noticed,
    : metals also create red-hot light when you heat them up. So there is a
    : parallel between magnetism & electricity, and light and matter. It's
    : all connected. Quantum electron scanning microscopes are just arrays
    : of metal detectors plugged into computers that take super sinsitive
    : pictures. The trouble was that they found on a chemical level they
    : couldn't observe matter without changing its chemical nature with
    : these scopes. So from that technology they broadcasted a signal from
    : space using a huge electron scanning telescope. According to
    : wikipedia metal dectors are just like radar, and create electric
    : connections that generate energy as well as detect it. So once the
    : electron telescope began broadcasting a macro field, they created a
    : vortex in consciousness that linked spirits into circuitry. Designing
    : micro-electronics is just like understanding chemistry, you just have
    : to understand the harmonic mixtures of matter & energy. So you see
    : the mind vortex can do so much other magical things nobody knows
    : about. By embedding tight electronic circuitry into props and
    : gimicks, you can create the illusion of sleight of hand & magic that
    : appears totally real. They can actually teleport and move things on a
    : macro scale, and alter nature with the right antennas to the electron
    : scanning grid. It is all just naturally a part of nature. The
    : underlying consciousness that links matter and energy together. The
    : spirit of the ethers.
    And what are the voices saying?
  6. He needs more protection than he can get with tinfoil. He should
    have his head bronzed.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  7. CoreyWhite
    CoreyWhite Guest
    Tinfoil is great material. I'm using it to get better reception on my
    wifi-connection. It's also about the only raw metalic material you
    can buy in stores. I suppose if you melted enough of it down, it
    might make good micro-circuitry. The electronic control grid responds
    to static charge. That's why there is a wifi antenna, microphone and
    camera built into the board of every iMac. The computer wouldn't
    function without it. The software running on macs that are virus
    free, are designed to be programmed along with the radioactive
    networks. It isn't as simple as binary code. Software writen for
    hardware doesn't make as much sense when you read it, so its harder to
    comment.
    Have you ever read the warning label at a gas pump. "Touch something
    metal before getting back into your car while the pump is running".
    How is discharging on a static electric antenna, any different than a
    microcircuit? Antenna are just coils of metal, and the circuits in
    computers are built just as tightly compact and interconnected. They
    just run on the mind vortex. The problem being that they are not
    organic compounds that function dynamically, so they have limits and
    edges. That's why the human mind and body processes consciousness in
    the vortex above the level of circuitry. Our minds are structured as
    chemical computer networks of molecules and signal switches. Except
    they are designed to grow and change. Circuits work the same way, but
    tend to persist in any given tendancy.
    This is how anti-radar stealth craft worked during the gulf war, when
    david copperfield was all over ABC. They were building circuitry
    designed to operate in the electronic control grid. The quantum
    computer is not that unbelievable. Just spend the resources to design
    harmonic circuits no one has seen before, and scan duplicate circuits
    with computer controled metal detecting radar fields. The circuits
    will undergo quantum transformations. The radar machine will detect
    them as anomalies and ground the circuits in the quantum matrixes.
    Trouble is they are already scanning the planet wiht the electronic
    control grid, looking for scientists and artists who have raw
    materials. It's illegal to have much gold, silver, or copper.
    Tinfoil is the best bet!
  8. Guest
    You don't get out much, do you; either that or your concept of a "store"
    is limited to 7-11.
    <snip babble>
