The distance between two pulses
Discussion in 'Microcontrollers, Programming and IoT' started by bravehamid, Apr 9, 2015.
  1. bravehamid
    bravehamid
    27
    Dec 10, 2014
    hi
    i want To measure distance between two pulse with vhdl
    in mind,what can i do?
  2. Sci-fi guy
    Sci-fi guy
    6
    Oct 12, 2014
    Create a counter process that will start with the first pulse and end with the second pulse. The process can count the number of clock cycles that occur between the events.
  3. bravehamid
    bravehamid
    27
    Dec 10, 2014
    As a result
    I can with number of counter and frequency of my board's calculate it
    Is that correct?
  4. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Yes, but understand the result you get may be a little bit off.
    So, if you can, use a more accurate clock source. (internal clocks are prone to drift and error, so using an external oscillator is ideal)
    Additionally, the math you use could introduce rounding errors.
    This is a great way of doing it though.
