Thévenin equivalent circuit
Nadun Palmada
Nov 10, 2015
4
Nov 10, 2015
4
Hi guys can someone please help me with the following problem:
I have figured out the Rth by turning the current sources to open and voltage sources to closed loop and i got this to be 50ohm but not sure how to do the Vth.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
you need any two of:
- open circuit voltage
- short circuit current
- equivalent resistance
from any 2 you can get the third, and that leads to a fairly simple Thevenin or Norton equivalent.
Nadun Palmada
Nov 10, 2015
4
Nov 10, 2015
4
I am not sure how to work out the open circuit voltage! I have come to these assumptions: No current will flow through either the 4ohm or the 6ohm resistor. Therefore would i jst take the voltage drop across the 40ohm to find the Vopen circuit?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,886
Jun 21, 2012
4,886
Don't forget to include the 520 V that is dropped across the 260 Ω resistor. This voltage is in series with the voltage dropped across 40 Ω resistor to determine the open-circuit voltage between nodes A and B.
GPG
Sep 18, 2015
452
Sep 18, 2015
452
what polarity is the voltage across 40Ω?
